Help me put the rest of my motor together
Old Dec 4, 2010 | 10:33 PM
jkrustchinsky's Avatar
Car: 1982 Trans Am, 1986 Gmc sierra
Hello forum, i just dropped a rebuilt 305 engine in my car and decided to say screw the crossfire injection and pulled out the harness. Now im sitting here with my **** in my hand looking at a pretty new engine, with no intake or carb.
Ill do a cam swap a little later down the road, but right now i want to have all my basics covered to start driving, and having respectable power, as much as a budget built respect can be.
Im looking at options, Im able to conjure up about 500 bucks for my carb setup. Can the seasoned pro's give me some best reccommended parts, as much usuable power and quality, thanks, Joshua
Old Dec 5, 2010 | 07:35 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Help me put the rest of my motor together
You'll have a lot of that $500 left over if you buy an Edlebrock 2101 intake and a used Q jet carb.
Quick, cheap, easy, effective solution.
Old Dec 5, 2010 | 07:35 PM
86jjk656's Avatar
Car: 86 Firebird
Engine: chevy 366ci
i like the torker II edelbrock single plane. its low profile fits neat under the hood and its realitivy inexpensive, also edle brock carbs are easy to set up and tune. youll end up spending about 400 if you buy new, then there is always craigslist.
Old Dec 5, 2010 | 07:40 PM
91V6firechicken's Avatar
i think summit has intake/ carb kits, not sure if they are in your budget or not but its worth a look
Old Dec 6, 2010 | 01:34 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Originally Posted by 86jjk656
i like the torker II edelbrock single plane. its low profile fits neat under the hood and its realitivy inexpensive...
It's also relatively worthless. You don't need a low profile, low flow, narrow powerband intake on a 3rd gen SBC. A drop base air cleaner takes care of any hood clearance nicely.
You need a non-computer, vacuum/mechanical advance distributor as well if you go with an aftermarket carb.
The only legal options are EFI, or computer controlled q-jet. You should be able to pick up a complete removed CC carb system for less than your budget, with enough left over for gaskets, hoses, carb rebuild kit, and the like.
jhawkeye
May 25, 2022 06:33 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
slade5612
Aug 11, 2015 07:19 PM
3rdgenparts
Aug 8, 2015 07:09 PM
Leggman1
Aug 6, 2015 04:15 AM
