TBI to Carb Questions
Car: 1988 Chevy Camaro
Engine: 305 TBI
Axle/Gears: Posi
I have an 1988 Camaro with the 305 5.0L that I would like to convert from TBI to carb. I've read through the tech articles and the threads I could find.
If anyone could answer these questions for me, I'd greatly appreciate it.
1) Will I be able to use the stock hoses for the fuel (to the AFPR, and return line back to the tank)?
2) Does the fuel pump need rewired? If so, how?
3) Can you recommend a specific distributor that I could use (preferably one by MSD) or the specs that one must possess?
4) Can I just get a non-EGR intake manifold and delete the EGR?
5) Is there anything else I'm looking over or haven't thought of yet?
Thanks in advance for the help.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Engine: 305 TBI
Axle/Gears: Posi
Re: TBI to Carb Questions
Car: 82 Z28
Transmission: T400
run a wire from key to pump relay
See
http://www.summitracing.com/search/P...o/?keyword=msd
Yes
Need some way of turning radiator fans on
Engine: 305 TBI
Axle/Gears: Posi
Great. Thank you for the information. The previous owner already wired the fans to the ignition so that shouldn't be a problem. It seems like a pretty simple, straight forward swap.
Transmission: 4L80E/4L80E
One needed thing that is not mentioned is the transmission TV cable geometry corrector bracket that mounts on the carb throttle arm. Which one you needs depends upon what carb you get.
Engine: 305 TBI
Axle/Gears: Posi
My car has the five speed manual transmission though, so I wouldn't have that cable, would I? IIRC I have one cable for the throttle and another for the cruise control.
Also, when switching from a computer controlled to a non-computer controlled distributor, wouldn't the wiring for the distributor change? Is there some sort of harness adaptor I would need?
Engine: 305 TBI
Axle/Gears: Posi
Bump. Help please. I need to buy parts so that I can pull her out and get her all fixed up in the spring.
Car: 1987 Firebird Formula
Engine: 2004 LQ4
Transmission: T-5 WC
Engine: 305 TBI
Axle/Gears: Posi
Alright. So what about this setup:
Dizzy: http://www.summitracing.com/parts/MSD-8362/
Carb: http://www.summitracing.com/parts/EDL-1801/
Manifold: http://www.summitracing.com/parts/PFS-52001/
AFPR: http://www.summitracing.com/parts/QFT-30-900/
On a stock 1988 305 5.0L.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Distributor is fine.
Carb - expensive for what it is - look at a standard Edelbrock 1406 carb - $100 less, more cfm that will do fine on the 305, and easily feed a 350 later.
Intake - I would take the savings from the carb selection, and put it ito a better intake - look at a Edelbrock Performer RPM - it's what most of us use because it's a great intake.
FPR is fine.
On the fuel pump - the ECM controls the fuel pump. No ECM and the fuel pump won't prime anymore. Not an issue since a carb holds fuel in the bowls (plenty to start and run car for a few minutes). Youe fuel pump will run as soon as the oil pressure sending unit senses oil pressure (a backup built into the system), so the car will start and run fine, unless it's been sitting for a few weeks and the gas in the carb bowls has evaporated down - even then it will still start and run, just takes a few seconds for the OPSU to sense the oil pressure building up from starting and turns your pump on.
BUT - most folks wire the fuel pump relay so that it runs as soon as the key is turned on. It's a simple matter of cutting the wire from ECM to relay, and putting 12v to that wire from a key-on source.
FPR is fine.
Engine: 305 TBI
Axle/Gears: Posi
Great! I'll take your suggestions into consideration. Thanks for the information!
Engine: 305 TBI
Axle/Gears: Posi
Mechanical secondaries are required for a manual transmission, correct? What is this Edelbrock "air valve" thing? Is that the same as a mechanical secondary?
Mechanical secondaries are recommended for manual transmission.
The "air valve" limits air flow when the secondary throttle blades open to prevent bog - it takes a little time for the fuel to work its way through the secondary metering system when the secondaries are opened, and without fuel to go with the air, you get bog. A "double pumper" or "dual squirter" mechanical secondary carb adds extra fuel as the throttle blades open to give you some fuel until the metering system can kick in.
Carter AFB, Edelbrock Performer series, and q-jets all use an "air valve" set-up. Others have used it as well over the years, but those are the carbs you'll likely see in 4 barrel versions these days.
Engine: 305 TBI
Axle/Gears: Posi
So would that air valve system work okay with a manual transmission, or should I look for a double pumper?
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
this thread has also been very helpful to me so thank you element. But i do have the 700r4 so i will need that tvc bracket. now my question is what kind of advantages are going to come with "the correct" Carb set up? from the stock TBI. looking for non biased answers but actually experience with this swap.
It will work okay. The only "issue" with the air valve is when you shift while during WOT runs. There will be a slight delay as the air valve closes and reopens. Better than a vacuum secondary carb, for sure.
Engine: 305 TBI
Axle/Gears: Posi
Is the vacuum advance distributor okay, or would that have problems with the manual transmission?
Car: 1987 Trans Am
Engine: LQ9/L92
You need a distributor with mechanical and vacuum advance when not using a computer controlled system. The vacuum advance is not affected like a vacuum secondary carb is.
Car: 91 RS Camaro
Engine: 305 TBI
Axle/Gears: 4.11
so what about the transmission if i ran my 91 rs 305 carb and ripped out the ecm how would my tranny know when to shift?
Car: 1992 RS
Engine: Carbed 350
Tranny will shift fine - the TV Cable determines shifting. You'll need a TV Cable Geometry corrector ($20) for your carb linkage. The only thing about the tranny controlled by the ECM is the torque converter (TCC) lockup - you'll need a method of locking it - either wiring a switch, or using a kit that goes into the trannny - there's a sticky on the carb section about TCC Lockup.
Car: !988 Camaro z28
Engine: Blueprint Engine Chevy 355ci
Transmission: 700 Corvette Servo
Axle/Gears: 4.11
Thanks for all this information! im about to do this swap myself tomorrow
