Distributor question...tpi to carb.
Old Feb 20, 2011 | 10:29 PM
5.SLOW's Avatar
Car: 1991 Z28
Transmission: 700-R4
Axle/Gears: 10 bolt Disc/Posi
ive tried to search but only found a bunch of people asking the same questions about fuel pumps and regulators over and over and over again.
I have a 350 tpi with a msd pro billet distributor and msd blaster coil. I have an intake manifold (edelbrock), carb (holley), and a fpr is on the way.
I want to know why i would have to change distributors, if at all. Can i run my msd stuff if i purchased a seperate ignition box? (eg. msd 6a or 6al?)
If i do have to change distributors, what type should i be looking at?
Old Feb 21, 2011 | 10:35 AM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Distributor question...tpi to carb.
You'll need a vac-advanced distributor. The distributor you have (if it was the one with the TPI setup) is computer controlled - since you are swapping to carb, you no longer have a computer to control that distributor (the computer might still be there, but none of the sensors are connected, so it's useless now). Since there is no computer to control that distributor, you have no way of advancing the timing. So now, since the swap to carb, you have to use a distributor that has springs/weights inside to advance the timing with centrifugal force, and that has a vacuum canister on the side to assist in advancement as well.
You'll also need a way of locking the torque converter now that the computer is useless. You'll also need a TV cable from a TBI or carbed car, a good sturdy throttle cable bracket, and the right TV cable geometry corrector for you carb.
Old Feb 21, 2011 | 12:30 PM
5.SLOW's Avatar
Car: 1991 Z28
Trans has been built and locks up hydraulically instead of electronically. So no issue there. Cables arent really a concern.
Just didnt want to throw away a $300 distributor for no apparant reason, ya know?
Old Feb 21, 2011 | 01:09 PM
theNMBR27's Avatar
Car: 91 Z28 / 04 GTO
Engine: GMPP 350 TPI / LS1
Transmission: WC T5 / T56
Axle/Gears: 3.23 / 3.46
You don't have to throw it away, send it to me! I have a brand new HEI (big cap) distributor that I'm don't need because of the TPI
Old Feb 21, 2011 | 02:25 PM
Car: 1992 RS
Engine: Carbed 350
ebay that sucka!
Old Feb 22, 2011 | 05:47 AM
kingzrt's Avatar
Car: 1987 IROC-Z
Engine: 5.0 305ci 4 barrel Edelbrock carb
Is there one place better than the other to connect the vacuum line too from the vac advance? I have a quadrajet carb
Old Feb 22, 2011 | 11:48 AM
Car: 1992 RS
Engine: Carbed 350
Is that Quad a computer controlled quad? If so, you need a computer-controlled distributor. You have to have a computer controlled distributor with a computer controlled carb, and visa versa.
If it's not a cc Quad, then whichever vacuum port that is what's called "ported" or "timed" vacuum - it will not have suction on it at idle, but will at higher rpms. That's where most connect to. Some connect to full manifold vacuum (has suction always) and their particular motors run better for whatever reason (I guess they are getting timing advanced some during idle, making their base timing a tad higher and thus getting a tad more total timing in earlier or something).
Old Feb 22, 2011 | 01:51 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
I have a 350 tpi with a msd pro billet distributor and msd blaster coil. ...
You can use a programmable box, but it will cost you about twice what a mechanical/vacuum advance distributor will cost you.
It is possible to use a computer-type distributor in a race-only configuration. It's basically the same as using locked-out timing w/o vacuum advance.
But, if this is intended to be a street car, get either a programmable box, or a mechanical/vacuum advance distributor. You could get a Pro Billet distributor and reuse the Blaster coil - the 8360 is ready-to-run, just needs your coil. The 8361 requires a box (like 6A, 6AL, etc.) and your coil. Or, the 8362 is self-contained, and you could sell both your current distributor and current coil (least expensive of all those options).
Old Feb 23, 2011 | 12:20 AM
5.SLOW's Avatar
Car: 1991 Z28
Thanks bro. Very helpful.
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Jlanz55
Sep 29, 2015 08:55 AM
Damon
Sep 26, 2015 04:29 PM
