Demon Carbs
Old Jan 23, 2011 | 09:30 PM
BrandonSB's Avatar
Car: 1987 Z28 Camaro
Engine: 30Slow
Demon Carbs
any opinions on Demon Carbs?
Old Jan 24, 2011 | 09:36 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Re: Demon Carbs
They get the job done.
Old Jan 24, 2011 | 09:42 AM
BrandonSB's Avatar
Engine: 30Slow
Re: Demon Carbs
sounds like enough for me hahahaha
Old Jan 24, 2011 | 09:47 AM
EvilCartman's Avatar
Car: '82 Z28
Re: Demon Carbs
They're piles of crap, stay away and get yourself an Edelbrock.
The one I'm running is great, you just have to remember you can't just bolt on the thing and expect it to work perfect out of the box. Takes time and extra parts to get them dialed in, same with Holley or any universal carb.
Old Jan 24, 2011 | 10:03 AM
BrandonSB's Avatar
Engine: 30Slow
Re: Demon Carbs
thanks for your input, will avoid them so you recommend edelbrock?
Old Jan 24, 2011 | 10:23 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Demon Carbs
He's being sarcastic.
Old Jan 24, 2011 | 10:26 AM
BrandonSB's Avatar
Engine: 30Slow
Re: Demon Carbs
i figured that much, was a little confused haha.
Old Jan 24, 2011 | 11:00 AM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Re: Demon Carbs
Make sure you pick out the right carb for your application. Call and talk to a rep and tell them your combo or go here http://www.barrygrant.com/demon/default.aspx?page=5 and look at there selection guide to get a general idea of what you need.
Old Jan 24, 2011 | 12:01 PM
Car: '82 Z28
Re: Demon Carbs
lol sorry... I personally think they're a pretty nice carb and after looking at a lot of engine pics of some pretty quick drag cars, they're more popular than I thought. On this site they seem to get a bad rep but on others, not so much. If you can sit down, have the patience and the time to tune a carb, it'll be great. I've had a Speed Demon, Mighty Demon and currently run a Race Demon that I bought off of ebay for under 300 bucks. Yes, the brand new ones had metal shavings but that's easily cleaned out. No matter if you buy new or used, make sure everything is fine before bolting the carb on your engine.
Old Jan 24, 2011 | 12:36 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
Re: Demon Carbs
quick fuel, pro systems, or holley HP would get the nod from me. I had to clean out several demon carbs years ago because there was metal shavings inside everywhere, now I typically pick the other ones listed.
Old Feb 9, 2011 | 11:39 AM
jplp29742's Avatar
Car: 1986 camaro iroc z28
Engine: 385 stroker 700hp and nitrous
Transmission: 350turbo
Axle/Gears: 373
Re: Demon Carbs
i have one on my sons 78 trans am that i built for him 18years ago and it has always worked great,has never been apart except to replace front bowl gasket from sitting more than it is driven and it feeds a 680 cubic inch olds motor, its a 850,it was agrovigating to get diled in as much as i can remember but has been great since,stay with the holley as its easier and cheaper to get jets and etc. for and almost all parts stores carry parts for them.jplp
Old Feb 9, 2011 | 11:23 PM
Car: '82 Z28
Re: Demon Carbs
All service parts and jets are compatible between Holley and Demon carbs. One wouldn't be cheaper or easier to find parts for.
RedLeader289
May 28, 2019 01:47 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
IROC ZELLER
Sep 29, 2015 03:00 PM
efiguy
Sep 27, 2015 01:30 PM
