carb help
Car: 1985 Z28/1981 Z28
Engine: 85 383 stroker/81 350
Transmission: 85 fortes tko 600 /81 turbo 350
Axle/Gears: G P ford 9" in proces
carb help
i have an 81 z28 i recently replaced my stock intake and computer controlled card for a summit racing 600 cfm card and an edel intake,i have all the smog stuff unhooked,timing is set.when i try to take off with full throttle it spits and sputters after a few seconds then just dies.i checked my choke and it is fine.after it sits for awhile it will start and run good if i dont give it alot of throttle any advice would be good
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: carb help
If you had a computer controlled carb, then you also had a computer controlled distributor. If you swapped the carb for a Edelbrock, but didn't change the distributor to a vacuum advanced distributor, then you'll have problems. You can't swap carbs without swapping the distributor as well.
I didn't know 2nd gen cars had computer-controlled anything.
Re: carb help
the 81 was the only year i believe and it is crap thats when they went to throttle bodies.thanks for the info i should have thought of that
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: carb help
if it was a ccc you need to do the distributor as well you will have just about no advance . Thread Starter
Re: carb help
thanks dan im sure that is the problem something simple i didnt think about
Car: 1992 RS
Engine: Carbed 350
Re: carb help
Cool - learned something new.
BTW - 3rd gens had computer carbs until 1987. 1988 was first year of the TBI replacement. Not sure if there's a difference between the 1981 computer carbs and later years, but on the later years it was (and still is) the best carb setup you can get.
Transmission: 4L80E/4L80E
'81 was the only year for computer carbs in 2nd gens. As stated, the computer carb was used in 3rd gens through '87.
The '81 computer wasn't quite as good as the later 3rd gen computers, but it was okay, and the carb was fine. Replacing it with a non-computer carb was a waste of money. You lost your torque converter lock-up function in the process.
The best way to cut your losses would be to put the computer q-jet back on, fixing whatever was wrong in the process (if anything was wrong with it - if you thought you could increase power by replacing it, you were wrong). If you like spending money, then get the non-computer distributor as suggested above, and whatever kit you choose to get the torque converter lock-up function back.
Most likely the cheapest solution would be to put the computer q-jet back on (assuming you got an intake that will accept a spreadbore carb - if not, then that was another mistake). It would also be the route to take for the best power and economy.
Re: carb help
i changed it because i moved and no longer need smog i couldnt pass smog in cali because an exaust check valve melted my smog pump actuator could not find one for the life of me(i dont care about economy i have two camaros and an suv daily driver,but i love power)so i need a new dizzy and a converter lock up not too hard to fix thanks for all the info
Re: carb help
Five7kid is correct, you did NOTHING to increase your power. Not needing to pass smog is a good thing, but that doesn't mean you HAVE to dump the CCC system. What you effectively done was reduce your milage, made a lateral move powerwise ( or actually lost some ), require more modding and money to get your combo working properly, and worst of all you've spent money ( and you're still not done spending yet ) to get you to this point.
You can dump almost all of your emmissions stuff and keep the CCC system if you want.
Not for the primaries, which is what you're running on when economy is in view.
Re: carb help
why are poeple talkin bout economy,my 85 is my power toy this is another project of mine going stock is not an option the motor will be coming out next winter
Bottom line: No aftermarket squarebore carb will outperform a q-jet for either power or economy.
RedLeader289
May 28, 2019 01:47 PM
efiguy
Sep 27, 2015 01:30 PM
