help please! pump won't keep running.
Car: 94 short box
Engine: 377cid carbed
Axle/Gears: 3.43
so i got my carbed 377 running, took it around the block a couple time's ran pretty good, took it to work this morning and when i went to leave it ran for about twenty seconds then died, it seems that the fuel pump isn't running after it originally pressures up the system, i have oil pressure at the gauge so I'm not sure why its not running, anyone else have any idea's?
Car: 84 z28
Engine: 305 for now, lil more then stock
Transmission: 700r4 for now
Re: help please! pump won't keep running.
Relay shorting, i've heard bad filters buliding up pressure kicking off pumps, bad pump, make sure your using a return style regulator dead heads also build up to muck pressure
Car: 94 short box
Axle/Gears: 3.43
yes i have a return style regulator on it, the pump will come on when i turn the key on but some times i have to turn the key on and off two or three times before it does so, even when the fuel bowl is empty? is there a way to hot wire the pump from the engine bay so i can drive it home, work is about four blocks away. thanks
Car: 84 z28
U can jumper it at relay most have the schematics of which pin is what on the relay itself use a bigger gauge wire and only for short period of time should be ok w/4blocks but dont quote me on that and i dont suggest it but should get u home
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Yes. I spliced a run-only hot wire into the relay to get it to pressure course I didn't bypass the relay. You could try swapping another relay in and see if the fuel pump works. I doubt you would need the cooling fan relay for those 4 blocks.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It would help to know what car we're talking about here - so we could tell you what wires to jump at the fuel pump relay. I don't know about anyone else here, but I have no idea what a "94 short box" is at all
And given "94", doubt we have the wiring diags anyway. Is this a 3rd gen F-body car?
And given "94", doubt we have the wiring diags anyway. Is this a 3rd gen F-body car? Supreme Member
Engine: 383 SBC
Good point I just figured it was a 3rd gen. I normally don't even look at car details.
Transmission: 4L80E/4L80E
Car: 1992 RS
Engine: Carbed 350
So, you'll need to track down wiring diags for that year/model truck and find a spot to introduce new fuel pump wiring - we won't have that info here since it's not a 3rd gen F-body.
Car: 94 short box
Axle/Gears: 3.43
theshackle
Mar 5, 2017 06:37 PM
