1989 iroc carb help
Car: 1989 iroc z28
Engine: L98 350 carb
Transmission: built 700r4
1989 iroc carb help
Ok today i started my car up fine. well i went and replaced the intake gaskets as they where leaking oil. when i put every thing back the car will not start and fuel just shots out the carb. pulled the plugs they where black cleaned them off put everything back still wont start any ideas
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 1989 iroc carb help
If you didn't set TDC#1 on compression stroke before you removed the distributor, then you'll have to get TDC#1 on compression stroke now, and wherever the rotor points make THAT the #1 spark plug wire, then rerun the wires to firing order clockwise on distributor.
Car: 1989 iroc z28
ok it was very easy fix i pulled the distributor out and the number 1 plug made sure it was at top dead center then reinstalled the distributor i think i had it at 180 degrees once i did that started right up and re timed with my light at 10 degrees advance runs great and went on the street and sprayed to make sure no pre detonation all good
Car: 1989 iroc z28
thanx again for the brain storm felt like a newb just was in a rush to get ti back together
Car: Bone stock 1989 Iroc T-Top,1991 Z28
Engine: 5.7, Carbed 383
Transmission: 700r4, T-56
Happens to all(or some) of us. I just rebuilt a t-56 and smoked it because I forgot to fill it with oil!
mustangman65_79
Aug 11, 2015 03:17 PM
1989, 350, 350s, car, carb, carbed, carberated, carbureted, carburetor, distributor, fl, iroc, jung, psl, z28
Retime the engine ..if the flooding is excessive, you might have a stuck fuel inlet needle
