holley vs. edelbrock
Old May 6, 2011 | 10:36 PM
steve90rs's Avatar
im trying to get a good idea on what people are running on their everyday/ weekend. carbed camaro. ive got a guy that is telling me edelbrock but just got my holley rebuilt and tuned. give me and idea on what you guys/girls are running on your car?
Old May 6, 2011 | 11:44 PM
Confuzed1's Avatar
Car: 83Z28 HO
Transmission: G Force 5 speed
Re: holley vs. edelbrock
I've ran both for years. Honestly, I've always thought they both have thier place.
On a strictly performance oriented viewpoint, a Holley or Demon DP comes out on top both on the strip and dyno over Edelbrock. It can be more fine- tuned than an Edelbrock - but I've always found them much more finicky. but that's what I've ran on my cars most in the past.
An Edelbrock design is less finicky, but just can't be fine tuned to the degree a Holley can - nor is it designed to be as performance oriented. BUT - for a DD type car, I've found them pretty darn reliable, and overall gas mileage is better. It's all in what you're looking for. - Just MO, I'm sure others have thier own...
Old May 7, 2011 | 01:54 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
I'm running Edelbrock, no complaints here at all with it. Like everything else, I think it boils down to opinions and personal preference. Why I have a Edelbrock? Because I bought the motor with it on there - no need to fix something that ain't broke (in my book).
Old May 7, 2011 | 02:25 PM
crytical point's Avatar
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
I used a edelbrock for years on my 83 z28 but had one bad backfire through the carb and it was toast but they are easy to rebuild
Old May 7, 2011 | 03:30 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
What did your backfire do to it?
Old May 7, 2011 | 03:49 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
it blew out some seals and took out a valve in it but it was caused by my spark control not adjusting the timing for the nitrous but I still have the carb it was a performer 750. Though I prefer holley between those two but my favorite carb is a weber but thats apples and oranges.
Old May 7, 2011 | 06:35 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You're sure it was an Edelbrock?
Old May 7, 2011 | 06:50 PM
Car: 92 RS Camaro
Engine: 305 TBI
Axle/Gears: 3.08
yea I am 100% sure it is a edelbrock 1407 I know they don't have power valves but it destroyed something that looked like a valve. After the big backfire it would stall around corners or hard acceleration and flooded really bad.
Old May 8, 2011 | 06:00 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
I am and have run Holleys for years, currently I am using a 750HP on my 385, like it says above: Better performance and finer tuning capabilities. I have had the oppurtunity to install and setup a couple of Edelbrocks on customers cars. My overall opinion is it's a good carb easier to dial in, bettermileage and a good DD setup...Just my opinion!
Old May 8, 2011 | 03:58 PM
steve90rs's Avatar
im not too conserned on mileage honestly. i drive the car 2 miles a day to work round trip. i bought the car with a holley and it needed rebuilt so i got it done and tuned by a shop and my buddies are saying i should have ran edelbrock because of the power valve problem for my daily driver. they car has a 327 in it nothing special all stock and i run a 650 vacuum secondary holley on it.
Old May 8, 2011 | 07:57 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
i have an edelbrock..no issues.
Old May 9, 2011 | 10:55 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
If you're going to just bolt on and go, then either one is fine. If you're going to play with it, then use whichever one you understand best and are most comfortable tuning. For maximum performance, use a DP isntead of an Edelbrock.
Old May 14, 2011 | 12:41 PM
massac3rd's Avatar
Car: 1986 z/28
Engine: 5.0 carburated
Axle/Gears: 2.73 gears
edelbrock is good for everday use but holley is much better for performance. the only issue ive ever had with my edelbrock 650 though is the placement of fuel lines on the top. every Holley Ive ever had has been great. but as previously mentioned edelbrock is much easier to rebuild.
Pac J
May 17, 2020 10:44 AM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
Royal_Z
Sep 30, 2015 08:45 PM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
