where to find kickdown bracket
Car: 85 Z28
Engine: 327
I have looked everywhere. Does anybody sell. 85 camaro 700r4 tranny quadrejet carb. I know I could go to junkyard, but here they are not as comman
Car: `86 SS / `87 SS
Re: where to find kickdown bracket
Don't limit your search to f-bodies.
Both 200-4R and 700-R4
Caprice through '88
Camaro through '87
Monte Carlo through '88
Trucks.
Most anything with a SBC and OD trans. will have what you need. Cutlasses came w/ SBC sometimes.
With a SBO, their bracket bolts down differently but would probably work for you.
Caprice through '88
Camaro through '87
Trucks.
Car: 85 Z28
Engine: 327
,That's the thing. I have a bracket from a truck on iit and my throttle cable is good but the kickdown cable is about a half inch angled to the right , the the guy at carb shop said I needed one from a camaro
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
I am assuming you are talking about the tv linkage. I found a link that showed the geometry of the linkage, and fabricated my own. They are also available from Summit. What tranny did the carb mate up to? If it is a 700 you should be all set.
Car: 85 Z28
Engine: 327
I looked on summit. Didn't find for quadrajet. But I think I can make an edlebrock one work.
It's one of the two that work on q jet. If you call summit, they will tell you which part to buy.
Squeaky8791
Feb 5, 2020 08:29 PM
ambainb
Apr 25, 2016 09:21 PM
evilstuie
Apr 14, 2016 08:52 PM
Genopsyde
Nov 11, 2015 10:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
