Edelbrock 1406
Car: 1989 Pontiac Firebird FORMULA
Engine: Rebuilt Chevy 350 in 2007
Transmission: 5 Speed Borg
Edelbrock 1406
ok so my car (89' Firebird Formula) runs and drive great she really pulls at 75% throttle........BUT when i go WOT there is no pull????
Engine Specs (it was pull out of an 89' Suburban LB9)
-Board 30 over
-deck shaved
-STOCK HEADS
-Stage 2 duel rise Intake manifold (Summit)
-Hooker Shorty Headers no CAT to 3" exhaust to magnaflow muffler
-Edelbrock 600cfm 1406 CARB
-Mallory 4309 FPR
my summit fuel pressure gauge is steady at 5.5 PSI even under load ( i can see threw the off center hood induction to my gauge) i think i am running to lean but i don't really know how to tune a Carb, do i need to calibrate it with SEATS, RODS ect
-Board 30 over
-deck shaved
-STOCK HEADS
-Mallory 4309 FPR
Car: 86 Z28
Engine: Built 312
Axle/Gears: 10 bolt 3.42
Re: Edelbrock 1406
Try playing with the springs first- go a bit stiffer.
If that doesn't work, then play with the rods and jets. If you have the manual, there's a 'map' in it that shows the stock combo, and where each combo of jets/rods will put you.
Re: Edelbrock 1406
is this what your talking about http://www.summitracing.com/parts/EDL-1487/?rtype=10
Car: 86 Z28
Engine: Built 312
Re: Edelbrock 1406
The springs are inside the carb.
Looking at it from the front, on each side on the top there is a Torx screw holding down a oblong/melted jellybean looking cover. Your springs, rods, and jets are under those plates.
http://www.youtube.com/watch?v=I0cuI...8C50E21C1BE825
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Edelbrock 1406
Springs won't have anything to do with it.
Read the Edelbrock manual and follow the step-by-step process they have for tuning. You won't find a simpler explanation.
And get rid of the triangle-of-death air cleaner before your car chokes on it.
Car: 86 Z28
Engine: Built 312
Re: Edelbrock 1406
That's what fixed mine when I had an identical problem. The stock springs were too soft for 75%- WOT and weren't making the rod to pull out of the jet.
Engine: 383 Carb
Transmission: 4L60
Re: Edelbrock 1406
Follow the instructions from the beginning, and make sure you do all of the steps in order. Don't just jump to the end where you change springs.
Re: Edelbrock 1406
so i should go with EDELBROCK performer calibration kit P# EDL-1487 and richin it up, also whats a good SMALL air cleaner i like to see more of my motor ?????
Engine: 383 Carb
Transmission: 4L60
Pac J
May 17, 2020 10:44 AM
efiguy
Sep 27, 2015 01:30 PM
Night rider327
Sep 25, 2015 04:47 AM
