Is this idle feed restrictor supposed to be bent like this?
Old Jun 11, 2011 | 09:26 PM
Zerocyde's Avatar
Car: 88 Camaro
Engine: 416 Stroker LS
Transmission: Magnum F
Axle/Gears: 4.11
This is the best pic I could get of it. It's the one on the right side of the picture...
http://i99.photobucket.com/albums/l306/Zerocyde/024.jpg
I've been having trouble idling with the new engine. The carb is a street avenger 670, the cam is a thumpr. I recently got the problem almost 100% gone by cracking the secondary butterflies open a bit so I could close the primaries and still idle. Before cracking the secondaries open a bit, just to idle I had to have the primaries open so far that almost all of the transfer slot was showing.
Could this have anything to do with why I need so much air to idle? If it is, can I just carefully try and stick something in there to space it out properly?
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Sep 21, 2015 09:57 AM
Cameeeero
Sep 18, 2015 04:00 PM
db057
Sep 4, 2015 07:57 AM
86IROC112
Aug 21, 2015 07:20 PM
