need to know
Old Jun 23, 2011 | 09:47 PM
NeoTath's Avatar
Car: 1987 Firebird Formula 350
Transmission: 700-R4
need to know
i need to know what carb is on my car. i am clueless. here it is..
Old Jun 23, 2011 | 09:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: need to know
Edelbrock Performer
Old Jun 23, 2011 | 10:02 PM
whatever84's Avatar
Car: 84 Camaro
Engine: 357
Transmission: TH350
Axle/Gears: 4.10's / Strange LSD
Re: need to know
^^ Yep and it could be anywhere from a 500 to a 800cfm.
Mark.
Old Jun 23, 2011 | 10:07 PM
limitlessfbody's Avatar
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
Re: need to know
what kind of problem are you having with it
NeoTath's Avatar
Re: need to know
what air filter would be the best for this? i have a k&n air filter but i need the tube kit for it which is like $100. is there a difference between a edelbrock round air cleaner and a triangle air cleaner like as in which has better air flow between all 3 the circle, triangle, or my k&n air filter with the tube kit?
Old Jun 23, 2011 | 10:09 PM
NeoTath's Avatar
Re: need to know
oh no problem just needed to look up some stuff but still cant find it. you know where the detent cable goes on the carb? i need the pin for it cause it is holding on by a rigged screw that dont hold very well.
Old Jun 23, 2011 | 10:19 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need to know
No choke unloader, so my money's on 600.
Old Jun 23, 2011 | 10:20 PM
NeoTath's Avatar
Re: need to know
wow you guys know your parts to cars really well.
Old Jun 23, 2011 | 10:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: need to know
The Edelbrock foam triangle is known as the "triangle of death". It's worse than no air cleaner at all.
Any typical open air round air cleaner that clears the carb and fits under the hood should be fine.
That carb is missing the secondary air valve, you're probably going to find it stumbles pretty badly when you get into it.
Old Jun 24, 2011 | 06:51 AM
Car: 91 RS CONVERT.
Engine: 5.0
Transmission: AUTO
Re: need to know
just grab you a regular breather and put a filter on your valve cover. As far as the screw barely holding on i beleive its oreillys autoparts that actually have all those little ball ends and bolts for the linkages pacific for edelbrock dunno if you have an oreillys near you though
Old Jun 24, 2011 | 11:14 AM
NeoTath's Avatar
Re: need to know
thanks aperion i will buy a round one, and limitlessfbody i should go to a orellys and get the valve breather filter and buy theball end bolt thanks.
Old Jun 24, 2011 | 12:10 PM
Wiggles's Avatar
Car: 84 Firebird, 78 Trans Am
Engine: LG4 305 Qjet, Pontiac 400cid
Transmission: T5 Non WC, TH350
Axle/Gears: All stock
Re: need to know
Looks like an Edelbrock 1406, had one on my '79 bird. It appears that your pcv isn't connected either.
