Holley VS Edlebrock
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
Holley VS Edlebrock
Ok, I would like some advise from some people who have actually used both carbs. I am currently running an edlebrock 650cfm on a 350 bored .030 over and I am fairly satisfied with it. It is super easy to adjust and really only needs adjusting when the seasons change. However, I picked up a Holley 600 cfm P-80 not too long ago that needs rebuilding and I was thinking about trying it out. I have NO experience with Holley's but this one has the electric choke which I dont currently have on the Edlebrock. So which one is better? Is it worth rebuildling and trying out?
Car: 1985 Z28
Engine: '69 350 4 Bolt Main .30 Over
Transmission: 700r4/B&M Shift Kit and Flywheel
Axle/Gears: GM 10 Bolt 3.23 Gears
Re: Holley VS Edlebrock
I never realized true performance until I bolted on a Holley.I was running a edelbrock 750 on my .30 over 350,shaved and polished heads,weiand x-elerator intake,msd dist,blah blah blah,etc.The point is...I'm not badmouthing edelbrock at all.The carb performed very good.But when I bolted on the Holley street avenger I was blown away.The throttle response was way snappier,no lag at wot and it had noticable low end gains.Just my opinion.Next one I would like to try is the race carb with no choke,just bare essentials.
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
I love a good holley-based carb. They're real easy to rebuild with a ton of aftermarket support and modifications that can be done to them. I'd go with a Holley, but there's a lot of personal preference in this question.
well this car is not something that I take to the drag strip or anything. It is just my toy for riding around I guess you could say. I want a carb that is dependable and what I mean by that is doesnt have to be rebuilt every year. The Edlebrock has been pretty good I suppose. I had a problem with a float earlier this spring but I think it was because the car sat up for a few weeks with ethonol tainted gas.
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I have used both, right now I have a gary williams (holley) on my engine. But the edelbrock is a good carb, not junk. The holley is quicker tho, but its real picky on settings.
thanks for the input gentlemen. I thinking I might order the base plate and rebuild kit for the holley and give it a try.
Car: 1988 gta carbed 383
Engine: small block 4bbl
Axle/Gears: 3.27 g80
ive always found that the edelbrock is better for the guy that just wants to bolt a carb on "out of the box"and run,holleys are better for the hottroder that will make changes to see what works best-ive ran them both,and i love the holley on my z28,but the edelbrock never let me down either
Car: '89 Camaro Rs/ '87 Z28
Engine: 305 c.i. TBI/ 305 c.i. 4bbl
Transmission: 700r4/T5
Axle/Gears: 3.73 posi/ 3.73 posi
Edelbrocks are easy to tune but holleys are generally better for performance. I put a holley on my z28 305 with a holley intake and it made a world of difference.
Car: 1988 Camaro
Engine: 377
Axle/Gears: Ford 9"
I did it no problem. Had no experience with carbs at all. As you're taking it apart, take pictures of "steps" and label bags with where it all goes. It's pretty straight-forward as daunting as it might look.
Car: 83Z28 HO
Transmission: G Force 5 speed
Pretty much as said above, The Edelbrock is an older design and doesn't have as much adjustability as a Holley based carb. Nor is the Edelbrock as performance oriented, but neither are "junk".
Engine: gone
Transmission: gone
Axle/Gears: gone
Holley by a million miles. Or any holley style carb. ex. Demon, Quickfuel, etc. The throttle response is off the hook. And I say you gain 30 HP from going from an edelbrock to holley IMO.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
i find after 30 something years working on cars ect that ;holleys need constant tinkering to remain viable,edelbrock carbs are more set it and forget it.and yes i expect to get slammed for my humble opinion
Car: 86 IROC
Engine: 5.0 TPI
see, constant attention is what a holley needs ,if youre up for all that. then yes they do have a performance edge. however if you just want to drive your car then edelbrock carbs are the way to go
Engine: gone
Transmission: gone
Axle/Gears: gone
Every edelbrock performer series carb i have ever used/worked on has leaked down
RaverRacerX
Mar 17, 2026 01:49 AM
RedLeader289
May 28, 2019 01:47 PM
Royal_Z
Sep 30, 2015 08:45 PM
