will 850 work
Old Oct 12, 2011 | 06:13 PM
1983cameroman's Avatar
Car: 1983 camaro with88nose ground effec
Engine: 468bb
Transmission: 700r
Axle/Gears: 323 posi
will 850 work
468 8.5 comp herbertsolid 234/244@50555/578 112lobe sep 110lobe cen 781 heads 2polished206 172 valves 3 angle valvejob 1.7 full roller rockers pro comp air gap manifold 6500k hei dist the 850 has pluged power valves both ends 80 front 84jets back should it work on my combo thanks terryby the way running 3310 76jets on it now
Old Oct 13, 2011 | 12:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
An 850 will feed a 468 to ~6275 RPMs.
What will be the primary use of the car?
Originally Posted by 1983cameroman
... pro comp air gap manifold...
Which one, exactly? You appear to have a cam that spin above 6275 RPMs. A dual plane intake needs a little larger carb than a single plane intake. You might want to consider a Victor Jr. or a similar intake.
Those are pretty small valves as well, by the way. Why not 2.19/1.88's? With the small valves, the 850 would probably be big enough (and you're leaving a lot of power on the table).
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
