Opinions on fuel lines
Subscribe
Nov 4, 2011 | 05:32 AM
Hi,
Need to run some new -10AN fuel lines for my car. This project is taking ages, and draining me of cash. I need the most cost effective way of installing new lines?
Im using an Aeromotive pump, with a Holley 700 DP, modified for blowthrough.
Reply 0
Nov 9, 2011 | 02:41 PM
Re: Opinions on fuel lines
Ah, no replies, it was a bit vague. My question is, are rubber lines ok to use from the tank to the carb, or will I have to use braided?
Reply 0
Nov 9, 2011 | 03:17 PM
We used this on my brothers car, Very nice and easy to work with. I would never just use regular rubber fuel line for that kind of length. Good luck. http://www.summitracing.com/parts/SUM-220791-B/
Mark.
Reply 0
Nov 9, 2011 | 04:14 PM
you want as much hard line as you can get, braided rubber line is a suitable alternative. just bare rubber, no way.
Reply 0
Nov 10, 2011 | 02:40 PM
Quote: We used this on my brothers car, Very nice and easy to work with. I would never just use regular rubber fuel line for that kind of length. Good luck. http://www.summitracing.com/parts/SUM-220791-B/
Mark.
Yes, this sounds perfect. The price isn't too bad either.
Thanks for the replies
Reply 0
Nov 11, 2011 | 08:20 PM
again, no way id use just bare rubber from the tank to the engine bay. its a BAD idea.
Reply 0
Nov 12, 2011 | 06:38 AM
Quote: again, no way id use just bare rubber from the tank to the engine bay. its a BAD idea.
Although it looks like rubber, in the description it says it has an elastomer inner tube bonded with a reinforced textile braid, and covered in high-temperature synthetic rubber.
So it does have a textile reinforced covering.
Reply 0
Nov 12, 2011 | 05:28 PM
Quote: Although it looks like rubber, in the description it says it has an elastomer inner tube bonded with a reinforced textile braid, and covered in high-temperature synthetic rubber.
Exactly, It's not just rubber fuel line it's NHRA legal so it will be just fine for a street car.
Mark.
Reply 0
Nov 12, 2011 | 05:52 PM
i should have read the description better, by bad.
Reply 0
Subscribe
