carb leak?
Old Nov 6, 2011 | 01:06 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
carb leak?
anyone know why or what would cause fuel to leak from this area?
Old Nov 6, 2011 | 01:26 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: carb leak?
you need to be more specific, are you using a holley carb ? could be leaking from the supply line , metering block or pump diaphragm.
Old Nov 6, 2011 | 01:43 PM
86'Bowtie's Avatar
Re: carb leak?
Sorry its a holley 750 dp. mechanical secondaries. Would a leak like that cause my car to burn rich?
Old Nov 6, 2011 | 01:45 PM
Engine: Lb9
Transmission: M20
Re: carb leak?
internal leak ? power valve !!
Old Nov 6, 2011 | 02:07 PM
86'Bowtie's Avatar
Re: carb leak?
Secondary has no pv on the carb. Primary was recently replaced. Idk car seems too rich idling get that unburnt fuel watery eye idle.
Old Nov 6, 2011 | 02:28 PM
Engine: Lb9
Transmission: M20
Re: carb leak?
have you set the float level before adjusting the primary screws
Old Nov 6, 2011 | 02:52 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: carb leak?
From your descriptions, I'd guess the float level is set too high (remove the sight plug(s) and if fuel pours out...). Check the following for the adjustment:
http://www.holley.com/TechService/FAQ.asp
JamesC
Old Nov 6, 2011 | 03:14 PM
86'Bowtie's Avatar
Re: carb leak?
JamesC
Checked the float levels and gas doesnt dribble out unless you bump the car..i recently changed squiters from a .28 to a .31 primary and from a .31 to a .35 secondary. Car runs good jus stinks..can anyone give me a detailed description of how to adjust the transition slots ? Been searching and all that pops up is the holley tuning sticky. Im wondering if that might be an issue
Old Nov 6, 2011 | 03:21 PM
JamesC's Avatar
Re: carb leak?
The Holley tuning sticky at the top of the page is very good. Give it a peek.
JamesC
Old Nov 6, 2011 | 03:27 PM
86'Bowtie's Avatar
Re: carb leak?
Pics would greatly help, anyone have any tips or suggestions..
Old Nov 9, 2011 | 04:54 PM
86'Bowtie's Avatar
Re: carb leak?
update..leak no longer there replaced metering gaskets and carb cleaned air bleeds and anything that needed cleaning..changed jets from a 70 to 73 primary and from a 79 to 82 secondary. readjusted the curb idle screw, checked accelerator pump lash, and rechecked the idle mixture using a vacuum gauge. car seems to run good, still has a rich smell but not as bad as it was.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
makaveli09
Sep 15, 2015 10:43 AM
rjcme
Sep 5, 2015 01:23 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
