should i fix the carb or get a new one?
Old Mar 16, 2012 | 11:43 PM
KuroNeko's Avatar
Car: 1986 Firebird, 1992 camaro
Engine: 79' 350, 89 305
Transmission: TH400, 700r4
My firebird is VERY rigged and ive been taking it apart and correcting it. as of right now the only problem with the carb is: to start the engine you need someone to hold down the choke, as for everything else, the original plugs are chopped and redknecked in and then theres a nail in a hose as a plug (whats that hose for anyways?) so my question is, is it worth fixing this one or get another?
And the choke is always in this position unless you hold it
Old Mar 17, 2012 | 01:40 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: should i fix the carb or get a new one?
That's a screw being used as a vacuum plug. There's nothing wrong with plugging an open vacuum port if it isn't needed.
A choke is very easy to replace, fix, or adjust, and so doesn't justify replacing the entire carburetor.
It is odd that you are apparently puzzled by these things, but yet feel the need to use a word like "rednecked" to describe something the previous owner has done. I doubt that you were forced to buy this car from the PO, so it would seem more appropriate for you to take responsibility for what you have and go acquire yourself a book on the quadrajet carburetor.
There are also many write-ups and documents concerning your carburetor online that you can read or download. Your issue isn't 3rdgen specific, but is Quadrajet specific.
Here's a basic write-up (page 1 of 4):
http://vetteprojects.com/kstyer/quadrajet.htm
another:
http://www.highperformancepontiac.co.../photo_07.html
There are many out there.
The part in your first pic with the red wire going to it is the electric choke control.
It uses electricity to heat a metal coil that applies pressure to the choke actuator rod.
You want to make sure the rod is connected properly and then check out the function of the electrified coil. It may be broken, jammed, or not receiving 12v when the key is in the run position.
The choke should fully open when the engine is warm and has been running for a couple of minutes.
If you need more choke (closed more) for engine starting when cold, then that suggests another problem, and the carb may need a rebuild.
Old Mar 17, 2012 | 02:14 PM
ls427ray's Avatar
give it a shot and try to fix it. if nothing else, you will learn more about your car.
Old Mar 17, 2012 | 08:23 PM
KuroNeko's Avatar
no i didnt pay for it, it was an even trade for my 1998 camaro, the main reason i got it was because the body and paint is near perfect. i was planning on using this carb still, i just like to know all of my options
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
383cam
Sep 9, 2015 06:01 AM
Third_Gens_Rule
Sep 3, 2015 06:56 PM
GeneralIesrussi
Sep 3, 2015 03:23 AM
