i feel dumb for asking
Old Apr 9, 2012 | 01:48 PM
kmcn47's Avatar
Car: 84 Trans Am, 84 Fiero, 86 944
Engine: 5.0, 2.5, 2.5
Transmission: 5spd
bu what size specter air fiter fits in the l69 airbox i've searched in the computer at work (autozone) and it doesn't list one, but i know that there is one and i don't wanna spend the cash right now for a new k&n even if it would be better, thankx for the hep guys
Old Apr 10, 2012 | 01:46 AM
JTS's Avatar
JTS
Car: 83 Z28, 85 Burb
Engine: 305 Carbureted
Transmission: 5 Speed
Re: i feel dumb for asking
Have you tried the NAPA webiste?
Old Apr 10, 2012 | 09:33 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A K&N is not "better". It lets dirt particles through that paper filters stop. That's how they flow more (although a paper filter flows plenty to feed a q-jet). I pity the fools that waste their money on them, because they're sending their engine to an earlier death.
According to Autozone's website (and Advance Auto's website), the Fram filter is CA327. The STP filter is SA327. I don't see a listing for Spectre, but I don't know why you would want to use one of theirs.
Wix makes good stuff: http://www.amsoil.com/catalog.aspx?code=42101-EA
For the record, the L69 and LG4 air cleaners use the same air filter element.
Old Apr 11, 2012 | 12:25 PM
nickyakker's Avatar
Car: 1982 Firebird T/A
Originally Posted by five7kid
A K&N is not "better". It lets dirt particles through that paper filters stop. That's how they flow more (although a paper filter flows plenty to feed a q-jet). For the record, the L69 and LG4 air cleaners use the same air filter element.
The only thing i know for sure about those oil based air filters is that KN posted a bulletin about if you have a MAF sensor the oil seeps through and coats the sensor, giving you a lower reading for your engine, which ultimitly MAY make your transmission work harder/irregular and cause it to blow.
My boss had one on his diesel and it kept tripping his maf sensor and his engine light would come on, so he did the smartest thing possible...threw it out
Old Apr 11, 2012 | 12:33 PM
kmcn47's Avatar
Transmission: 5spd
whats wrong with a spectre filter? not looking big hp, just a good re washable filter for my dd
Old Apr 11, 2012 | 01:10 PM
five7kid's Avatar
Same thing that's wrong with a K&N - in order to get decent air flow, they have to have larger openings between the fibers, which allow more dirt particles through.
Old Apr 11, 2012 | 01:14 PM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
ive had bad experiences with spectre products. fuel regulater was a joke. fuel filter is a restrictive POS. not sure about the air cleaners, but based on my experience, id find something better.
JMO.
Old Apr 11, 2012 | 01:27 PM
kmcn47's Avatar
Transmission: 5spd
does enough get through to really hurt the carb? i mean i know the l69 airbox is supposed to have better flow then the regular lg4 airbox but it seems pretty restrictive still to me, i just wanted a better flowing filter to let more air through if its geting there at all, i'm not gonna run an open fiter, just looking for a replacement for the original filter (atleast i think so)
Old Apr 11, 2012 | 02:02 PM
five7kid's Avatar
Dirt doesn't hurt the carb. It is sandpaper to your rings and cylinders. Also gets into the oil and does the same to your bearings and lifters.
Old Apr 11, 2012 | 02:06 PM
kmcn47's Avatar
Transmission: 5spd
so just get a fram? lol anythings better then the brown dirty old purolator its got in it
Old Apr 11, 2012 | 05:59 PM
five7kid's Avatar
Yes. Nothing wrong with Puralator, either (when new).
Old Apr 11, 2012 | 06:05 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
You can also get a taller air air cleaner lid from a Monte Carlo or similar car and use a taller paper air filter. After reading the K&N dirt particle comments and experience with my Ford Explorer's wire sensor getting filthy, I am going back to paper.
Old Apr 11, 2012 | 07:42 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Paper or plastic lol I believe I will get a paper one also. It is almost always damp here in the rain forest but on the dry dusty days I will run paper.
Old Apr 11, 2012 | 09:33 PM
kmcn47's Avatar
Transmission: 5spd
well (and this will make me sound dumb, or at lest childish) i run with my air cleaner lid upside down so that at w.o.t my car makes that BWAHHHHHH sound that i fel in love with when i saw gators ltd in white lightning
Old Apr 12, 2012 | 06:55 PM
Edwardgp's Avatar
Engine: 454-350
Just got off work and just read your post and all that makes that sound a little better is the squealing of tires and the smell of burning rubber-smells like victory.
Old Apr 12, 2012 | 09:40 PM
kmcn47's Avatar
Transmission: 5spd
well i sometimes smell an oily smell aswell, i have looked that engine over top to bottom and theres no mobil 1 leaking out anywhere, but a bit of smoke on cold starts, is that normal? also
Old Apr 13, 2012 | 07:35 PM
Edwardgp's Avatar
Engine: 454-350
Well a little smoke on start up is OK but it means valve stem seals a little weak. Now if you are pumping the gas and then cranking on cold mornings then you are probably washing the oil of the cylinder walls.
Old Apr 13, 2012 | 10:33 PM
kmcn47's Avatar
Transmission: 5spd
as long as its not something serious, my dad said i need new piston rings and it sounds to me like i dont, so im glad its normal, mobil 1 is expensive to be leaking out haha
Old Apr 14, 2012 | 07:11 AM
Edwardgp's Avatar
Engine: 454-350
We don't want to dad an F on his trouble shooting but I have thought about this. Dad could also be right I need to know what one of your spark plugs looks like after you pull one out.
Old Apr 14, 2012 | 04:49 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Do a cyl leakage test and build yourself a 14" by 3" duel snorkel air cleaner.
Auggie
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
gord327
Sep 29, 2015 10:18 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
