What gas should I use for my lg4
Old Apr 21, 2012 | 07:54 AM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Would I get any benefit from running premium? Not looking for just performance, I care about keeping the motor healthy. I strictly use shell or chevron btw.
Old Apr 21, 2012 | 09:04 AM
Chris 84TA's Avatar
Car: 1984 Trans Am Convertible
Engine: 355
Transmission: WCT5
Re: What gas should I use for my lg4
no, lg4 has low compression... i always ran 87 and had over 300k on a stock lg4
Old Apr 21, 2012 | 10:10 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Owners manual specs 87 octane. Even though the '85-87 LG4s have around 9.5:1 compression they have a knock sensor to control any detonation.
Old Apr 21, 2012 | 07:49 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
On an 87 with the higher comp. ratio, you can run higher base timing with higher octane.
Old Apr 24, 2012 | 08:49 PM
Camaro305SB's Avatar
Car: 87 Camaro
Engine: 305 LG4 (H)
If its a stock car (or you have some SUPER nasty carbon built up on your pistons effectively increasing compression), anything other than 87 is a waste of money.
Old Apr 24, 2012 | 10:45 PM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
110 octane should work.
Old Apr 25, 2012 | 08:10 AM
Car: 87 Camaro
Engine: 305 LG4 (H)
^^ LMAO - smells better than 87 if you have no cat(s)!
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
