timing issue?
Old Apr 23, 2012 | 11:21 PM
firebirdfreak87's Avatar
Car: 87 firebird did V8 swap
Engine: sbc 350
Transmission: 700r4 shift kit and stall
timing issue?
ok I did a tpi to carb swap and got it fired up today but the exhaust manifolds got hot fast idk why and I can't remember if turning the distributor clockwise is retarding it or the other way around plz help
Old Apr 24, 2012 | 04:38 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: timing issue?
Assuming its an sbc, clockwise is retard and anti-cw is advance.
Hot manifolds could be retarded timing, or lean mix. Or normal, depends how hot I guess.
Old Apr 24, 2012 | 07:28 AM
Engine: sbc 350
Re: timing issue?
well if it was to advanced would they get hot fast it only ran for 5 minutes at the most
Old Apr 24, 2012 | 07:56 AM
redneckjoe's Avatar
Car: 87 iroc-z
Engine: 454
Transmission: th350
Re: timing issue?
http://www.youtube.com/watch?v=UYGU7mTwsZc
see if the video above in the link helps you out some.
Old Apr 24, 2012 | 11:15 PM
Engine: sbc 350
Re: timing issue?
it helped some but the problem I'm having is the manifolds get hot fast and unless I keep pressing the gas it won't stay running
Old Apr 25, 2012 | 02:09 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: timing issue?
As a total guess, bet you've got a vac leak, maybe at the carb base. Get the timing somewhere in the ballpark 10-12 degrees, then get a vac gauge on it and see what it's doing.
Old Apr 26, 2012 | 09:33 PM
Engine: sbc 350
Re: timing issue?
well itll stay running now but its at really high rpm
Old Apr 27, 2012 | 07:55 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: timing issue?
The timing was really retarded before (this will heat up the manifolds). Now that your timing is advanced, the idle speed will go up. Solutuion = turn the idle speed down.
Old Sep 17, 2012 | 05:34 PM
Engine: sbc 350
Re: timing issue?
Found out I didn't run the gas tank vacuum hooked it up car runs but it sucks gas like its pouring out off the lines as it sucks it threw
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
theshackle
Sep 17, 2020 08:26 AM
djmarch
Aug 9, 2015 05:27 PM
86Base
Aug 8, 2015 01:34 PM
