Engine swap
Old May 17, 2012 | 07:30 PM
God's.Gift's Avatar
Engine swap
I have a '92 camaro rs 25th anniversary edition. It currently has the stock 305 with a TPI, I believe. But I want to swap it for a 350 running a 6 pack carb.
My question is, do I need to do any conversion or am I safe because I'm doing the whole engine swap?
And does anyone know who makes a 6 pack carb?
Old May 17, 2012 | 08:39 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine swap
There will need to be a bunch of conversion work done to use a different induction system.
There's no such thing as a "six-pack carb". A "six pack" is a trio of two-barrel carbs. Multiple carb setups were used because multiple small factory carbs had to be used to get enough flow into large or high-performance engines. As soon as large enough 4 bbls started coming out, everyone abandoned multiple carb setups for practical use.
Old May 18, 2012 | 11:45 AM
91phoenix's Avatar
Car: 91 Firebird,00 c2500,75 Vette
Engine: 3.1 but 350 soon, 350, 350
Transmission: T56 soon
Axle/Gears: stock 3.42 Posi to come
Re: Engine swap
Look at the welcome to the carburetor forum at the top. It will give links to what needs to be done to swap to carburetor.
As to the six pack carb Apeiron is right. I might add that they were designed to have only the center carb for idle and the front and back open like the secondaries on a four barrel. They look sweet but can be hard to piece together a complete setup. The carbs are available rebuilt but some places do not offer all three. The front and back seem to be a little different from the center. This setup can be hard to properly tune as the front and back need to flow the same for proper tuning to keep from lean or overly rich conditions not to mention proper jetting.
I have seen complete setups sell for 1200 at swapmeets. This isn't asking price but what was actually paid. It included intake, carbs, linkage, fuel lines, and air cleaner.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
