Base timing is not influenced by the prom, right?
Old May 20, 2012 | 07:10 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Transmission: Manual
Axle/Gears: 3.70
This pertains to a carbed car, hopefully i posted in the right forum....
Old May 20, 2012 | 08:00 PM
Re: Base timing is not influenced by the prom, right?
Of course not. Not carbed or anything else.
"Base" timing is the mechanical alignment of the engine parts.
Old May 20, 2012 | 10:42 PM
rhalpin20's Avatar
Car: TA
Engine: 5.7 CCC
Axle/Gears: 3.70
Thanks. Can you tell me what does?
Sorry, guess i didnt read the whole post. Thanks again for the reply...
Last edited by rhalpin20; May 21, 2012 at 01:01 AM. Reason: Apparently i cant read
Old May 21, 2012 | 04:52 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
When you disconnect the ECM and set the timing at idle, that's typically referred to as the "base" timing.
With the ECM still disconnected, if you give it throttle and raise the RPMs, the PROM will increase the timing. It isn't much, but it is enough to affect the "base" timing if you have the RPMs way too high when you are setting it.
Old May 21, 2012 | 09:04 PM
It makes the pulse that the dist sends to the ECM, telling the ECM "do something now", to align with the moment that the engine's need for something to be done, occurs.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Glowsock
Jul 24, 2025 03:15 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
