Please help
Old Jul 6, 2012 | 07:32 PM
86Trans/AM's Avatar
Car: 86 T/A GTA Rims
Engine: 350 Mild cam 750 holly
Transmission: Beefed 700R4
Please help
I was driving around all day today and now my bird wont stay running... i have to give it gas and it dies if i dont. Its a duel pump 750 holly, i checked the float and its fine everything is fine on it... this just happened out of nowhere also if i romp on the gas it squeaks now and the belts are all tight please help me out im leaving for the summer nationals tomorrow and doesnt look like im going if this doesn't get fixed.
Old Jul 6, 2012 | 07:56 PM
scubasteve's Avatar
Car: 84 Z28 T-Top
Engine: L69
Re: Please help
Did you check your fuel pressure ?
Old Jul 6, 2012 | 08:25 PM
86Trans/AM's Avatar
Re: Please help
yes shes running 6psi
Old Jul 6, 2012 | 08:53 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: Please help
Holley? Older or newer style Demon?
Good clean filter?
Plugs good or fouled?
Sorry fir all the Qs, maybe someone can help dial it in with a lil more info??
Good luck
Old Jul 6, 2012 | 08:56 PM
Car: '87 Camaro
Re: Please help
Oops!! I see your sig says Holley!! DOH!!
Choke stuck or chokeless??
Old Jul 6, 2012 | 09:10 PM
86Trans/AM's Avatar
Re: Please help
choke is always open .. i just put this together last weekend and today was the first day i drove it around.. i was driving is for like 2 hours before this happened. There is a filter from the regulator to the carb
Old Jul 6, 2012 | 09:56 PM
Car: '87 Camaro
Re: Please help
Check throttle cable- good fit in the bracket? Pop out of bracket?
Squeak // squeal--
Serpentine
Check idler pulley
Water pump- loose hub // bearing
A/C compressor if eqpt
Power steering fluid level
V belt
Water pump hub // bearing
Just some 2 cents
Old Jul 6, 2012 | 10:03 PM
Car: '87 Camaro
Re: Please help
Check timing & distributor cap lock down
Old Jul 7, 2012 | 11:49 AM
TreeFiddy's Avatar
Car: '86 TA
Engine: '74 350
Axle/Gears: 2.77
Re: Please help
In lieu of the current heat you guys are having in the States - vapor lock maybe? Got a return regulator?
Old Jul 8, 2012 | 11:07 AM
86Trans/AM's Avatar
Re: Please help
i found out the carb was pumping to much gas... thanks for the info
