please help! running very rich
Old Nov 4, 2012 | 07:24 PM
brad_4291's Avatar
Car: 84 z28
Engine: 305 HO
Transmission: 5 spd
Axle/Gears: 3:73 posi
hi everyone. and thanks in advance for any help you can give me. i just recently purchased an 84 z28 with 305HO 5spd. motor was completely stock. i installed an edelbrock 1406 carb and 2101 intake with no spacer just gasket, a mallory unilite distributor with vac. advance connected to manifold vacuum, and all computer controlled wiring/components removed. it is running very rich at idle and not sure if it is while driving. the exhaust smells very rich. what could i need to do. also what do you think the initial timing should be set at and what should total timing be with the vac and mechanical advance. 32* a 3000rpm? thanks alot!
Old Nov 4, 2012 | 09:00 PM
brad_4291's Avatar
Car: 84 z28
Engine: 305 HO
Transmission: 5 spd
Re: please help! running very rich
it also has accel plugs, msd street fire plug wires, headers and full flowmaster exhaust. i have just rebuilt the carb making sure everything was adjusted properly and clean. right now the initial timing is set to 14*. sometimes if i rev it high (at a stop) it backfires out the carb. not sure if the initial timing is off or the total timing (have not checked total timing yet w/ the vac and mechanical) could the timing cause it to be running so rich or something w/ the carb. any body's input would be greatly appreciated because other camaros ive installed the edelbrock 1406 on ran fine right out of the box.
Old Nov 5, 2012 | 09:22 AM
camarito's Avatar
Car: 84 Z28 / 11 genesis coupe
Engine: 355/210 heads/275deh/Proform 750 DP
Transmission: 700r4/B&M 2400
Axle/Gears: 02, allu.axle, 3.42, posi
in my opinion that carb is too big for the stock 305, adjust the idle mixture screws as tight as you can without stalling the engine, i had the 500cfm on the 305 and ram nice, fast and smooth
14* is high i would keep it at 10* max
Old Nov 14, 2012 | 05:39 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
I would even say drop it back to 8*. factory spec is 6, but that's with the CC dizzy in it, I don't know how much of a difference there is between the two in regards to initial timing.
Old Nov 14, 2012 | 05:51 AM
freaky's Avatar
Car: 88 camaro irocz
Engine: l98 tpi
Axle/Gears: 2.77
my 305 with tbi idles at 14-16*an total timing is 37
Old Nov 14, 2012 | 05:54 AM
Ozz1967's Avatar
Car: 1984 Trans Am
My cc Qjet runs 6-8* initial/idle timing with ECM disconnected. With it hooked up, it's off the timing tab so I don't know how to check that.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
