hey guys, my camaro is my first carb. I bought it recently with a holley 650 in it, she's a nice engine. Well it's roughly 25 degrees where I am and it seems like if i pass roughly 2500 rpm and the car hasnt been running 10 minutes or so she shuts right off. Is that normal?? i'm used to fuel injection where I can just get up and go.
she does need a tune, thats pretty obvious. But, i'm just stumped. I tried to merge into traffic before I warmed her up and she cut right out. 82 z28 with a 350 swapped in guys. thanks
Do you have a functional choke system on the carb? It's purpose is to richen the mixture when the engine is cold. Without it starting and running in cold weather can be a pretty miserable experieince until things warm up.
Quote:
I believe its supposed to have an electric choke but it seems like there isn't one at all. that would explain it but i didn't think it could affect it that muchOriginally Posted by Damon
Do you have a functional choke system on the carb? It's purpose is to richen the mixture when the engine is cold. Without it starting and running in cold weather can be a pretty miserable experieince until things warm up. Quote:
Do you have a functional choke system on the carb? It's purpose is to richen the mixture when the engine is cold. Without it starting and running in cold weather can be a pretty miserable experieince until things warm up. funny enough damon im from philly but im out in the mountains near pitt right now
I have a similar problem. My qjet will start right up in the morning (15 degrees) but I need to hold it at at least 1000 rpm or it will die. Let off the gas and it shakes and bucks like crazy. I have to back down the driveway holding it at 1k and a foot on the break. But once I get the car into second gear it drives normal and the problems are gone. No idea what's causing it
Quote:
i was told it could be the pcv valve, here's hoping. simple thing can cause so much hell.Originally Posted by Gsoleski
I have a similar problem. My qjet will start right up in the morning (15 degrees) but I need to hold it at at least 1000 rpm or it will die. Let off the gas and it shakes and bucks like crazy. I have to back down the driveway holding it at 1k and a foot on the break. But once I get the car into second gear it drives normal and the problems are gone. No idea what's causing it Member
camarito
close
- Join DateApr 2010
- Locationsussex county, NJ
- iTrader Positive Feedback0
- iTrader Feedback Score(0)
- Car84 Z28 / 11 genesis coupe
- Engine355/210 heads/275deh/Proform 750 DP
- Transmission700r4/B&M 2400
- Axle/Gears02, allu.axle, 3.42, posi
- Liked:0 Times in 0 Posts
mine, when cold, dies as soon as i put it in drive if i use manifold vacuum on vacuum advance, no way i can get a 14:1 AFR at idle on manifold vacuum without it stalling as soon as i put it in drive after warming up for a minute or two but on ported vacuum idles great in drive even at 15:1
Quote:
well mine still dies if cold, I think its a choke issue. I was looking at my carb and the electric connector clip looks broken off labeled choke.Originally Posted by camarito
mine, when cold, dies as soon as i put it in drive if i use manifold vacuum on vacuum advance, no way i can get a 14:1 AFR at idle on manifold vacuum without it stalling as soon as i put it in drive after warming up for a minute or two but on ported vacuum idles great in drive even at 15:1 Member
If you don't have 12 volts wired to the choke then there's your problem. Get your choke working properly and you'll be good to go.
