Edelbrock Hard Start After Sitting
Car: 89 Camaro Iroc
After letting my car with a Edelbrock 1407 sit for a week i have to do 2-3 cranks of 10 sec for is to start. Is this normal for carburetor car as i have not own one before. Also is there a certain starting procedure to start.
Transmission: 4L80E/4L80E
Normal starting procedure for a carb'd car is to give the accelerator pedal 1/3-1/2 depression. This does two things: 1) put a squirt of fuel into the intake manifold, and 2) allows the choke butterfly to close and the high idle cam to engage.
This assumes you have an automatic (typically electric) choke. If you have a manual choke, you close it while the accelerator is depressed that 1/3-1/2.
The 1407 comes with a manual choke. Did you hook up a choke cable? Or, did you convert it to automatic electric choke?
Car: 89 Camaro Iroc
Re: Edelbrock Hard Start After Sitting
Yea it is still a manual choke but I have to pump it a lot more than a half press to get it to start should I adjust the floats I don't know if the carb is drying up. Should I pump it while turning it over.
If you fully close the choke when first depressing the accelerator, you shouldn't have to pump the accelerator at all.
Oh, should have said, "Depress the accelerator pedal 1/3-1/2 travel, close the choke, and let off of the accelerator."
If that isn't working, you need to determine why. Edelbrock carbs aren't known for losing fuel while sitting (other than from evaporation). You shouldn't change float settings to fix a starting problem.
Car: 89 Camaro Iroc
Ok I will try the way you suggest how to start it. But if it does not work what parts of the carburetor should I look at or adjust.
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
I have the same carb and have to do the same exact thing after letting it sit however I have an electric choke. usually I pump the gas 5-6 times and it cranks then dies, then I have to do it again to get it to start while playing with the throttle to keep it running. its not all that unusual from what I've seen.
Posted from Thirdgen.org App for Android
Car: 89 Camaro Iroc
Yea I have to do the same. But my friend has a 1406 and pumps it twice and it starts right up. Do you think a rebuild would help my problem or electric choke.
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Car: 89 Camaro Iroc
No I have an electric fuel pump. I adjust fuel pressure, timing, new spark plug, and I still have the same problem. So im out of idea's excepted a carb rebuild and insult carb and fuel lines. And buy an electric choke.
Car: 1986 Pontiac Trans Am
Engine: 350 cid bore too much to list.
Transmission: 700-R4
I am running this same setup on my T/A and I have to do the samething with the starting 2 or 3 times. One of the things on my to do list for this summer is to install an electric choke. My friend has an 86's Monte Carlo SS with the same set up we have PLUS the electric choke and his car always starts up nice.
Car: 94 camaro z28
Engine: lt1
Transmission: 4l60e
Mine still does it even with the electric choke hooked up, after sitting for a couple of days it plain doesnt like to start. Might be time for a rebuild though for me now that I think about it.
Car: 89 Camaro Iroc
Well I'll be rebuilding mine in a week or two I'll tell you if it help out with the starting problem.
Car: 1985 IROC-Z H.O. 4bbl
Engine: L69 Small-Block, 305
Transmission: Borg-Warner T5
Well u can add me to the list.. It takes 2 to 3 hits on the pedal to get that bch to start
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Do you have a mechanical fuel pump?
Same setup, mechanical pump, electric choke. I pump the pedal twice and it literally takes right off at the touch of the starter. Even in rather cold weather. If it sits for a month or so it takes a few revolutions though.
I am running a Carter Mechanical pump BRAND NEW running at 7 psi.
Car: 89 Camaro Iroc
What Rpm Should the fast idle be set to mine is around 1000 rpm is that normal for fast idle.
Car: 89 Camaro Iroc
I just check my oil today and found out it smells like gas is this a problem from the carburetor. I need help I don't know what it could be.
Car: 89 Camaro Iroc
No it not new but not real old what can I do to fix this problem rebuild the carburetor.
Check your float level. Check the needle and seat. May not be sealing well. Possibly a little piece of crud stuck in it? This would constantly dump gas while its running and let it drain out when it sits. You ever put a gage on the fuel line to verify pressure? Did you change from a mechanical pump that was bad? They will sometimes rupture the diaphragm and leak gas into the block.
Car: 89 Camaro Iroc
Easy to check. Pull the top of carb, flip it upside down, and a 7/16 drill bit shank between the outter end of float and gasket should just fit in, touching both. Bend the tab at the back that closes the needle valve to make this right if not.
Did you try just watching the vent holes while its running? Fuel will bubble out of them if its set too high.
Car: 89 Camaro Iroc
Car: 89 Camaro Iroc
Ok so i rebuild the carburetor and i'm still having the same problem. The bowls are not going dry but for it to start i have to pump it 6 plus times. Choke is adjust, new spark plugs, timing is adjusted. What else can it be. THANKS
Hot starting on my 1405 is crank and instant start.
Car: 89 Camaro Iroc
I'm not running a spacer but if I do hold pedal all the way down it does start better. What could be the problem also running higher octane gas help at all.
Car: 82,83,99 T/As
Engine: 350,350,383
Transmission: ST-10,700r4,4l60e
Axle/Gears: P-3.23,P-3.42?,P-4.10
Check for vacuum leaks. Sounds like what was happening to me when not all the ports were hooked up/plugged.
Car: 82,83,99 T/As
Engine: 350,350,383
If you still have all your emissions stuff, check all that. Smog pump, egr valve, diverter valves, etc. Vac advance. Pretty much make sure any vac hoses are not disconnected. If they are and they're not supposed to go anywhere, cap them.
Car: 89 Camaro Iroc
Aright i check for a vacuum leak and there is none. When it idles its not smooth the RPM moves a little. How much tight should the choke plate close when i close mine i have 3/64 of a inch. Is that correct?
Car: 1984 Camaro Z28
Engine: L69 H.O. 5.0 4BBL 305ci
My Q-Jet with the factory electric choke, etc. has the exact same problem. It sat for a month and hasn't been the same no matter how much I drive it, chemicals I throw in the tank, or carb cleaner I use. It has about 2,500 miles on it since rebuilding (2,000 interstate and the rest are highway and suburb driving).
