RETURN LINE
Old Apr 28, 2013 | 09:44 AM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
RETURN LINE
I have a 87 iroc with a carb. going to put a holley blue pump an a reg. the reg. does not have a return on it do i still need it if not what do you do with it ?Thanks
Old Apr 28, 2013 | 10:15 AM
Restrorob's Avatar
Car: 88 GTA
Engine: Built 355 to install
Transmission: Built turbo 350
Re: RETURN LINE
You will need a regulator since most carbs run 5-7 lbs pressure, I had two pumps fail running a non return regulator due to too much back pressure burning them up. A return style regulator can be picked up in the $40 range, Well worth the price in my book......
Old Apr 28, 2013 | 08:07 PM
Re: RETURN LINE
Get the right regulator. It will use the return line. You will not be happy with a regulator that doesn't have a return.
Old May 6, 2013 | 10:14 AM
mr z28's Avatar
Re: RETURN LINE
Do I need to change the 5/16 line to 3/8 to fit the regulator or just buy a fitting to go from 5/16 to 3/8 or can I use the 3/8 vent line by welding a extention tube to it an use it. Thanks.
Old May 8, 2013 | 02:46 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Adapter fitting.
Old May 9, 2013 | 05:21 PM
86mailman's Avatar
Car: 86 Iroc
Engine: 496
Transmission: 4l80e
Axle/Gears: 9" eaton posi 4:11
Re: RETURN LINE
what regulator do you recomend? Im doing the same thing, but with a big block 454 with a holley 850. Any part #s would be awesome.
Old May 9, 2013 | 06:19 PM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: RETURN LINE
The most recommended // installed is
Mallory # 4309
Old May 10, 2013 | 01:17 PM
mr z28's Avatar
Re: RETURN LINE
I have decided to go with a Holley mech. pump an no regulator its a 12-327-11 goes from 6 to 8 lbs. 87 iroc carb.350. I also heard that Big End Performance makes these pumps for Holley. Does anyone know if this is true an how good are they? Any kind of input on my choice of pumps without return line? Thanks .
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
R13_Braz
Sep 18, 2015 05:00 PM
armybyrd
Carburetors
25
Sep 13, 2015 01:49 PM
TBRays98
Sep 6, 2015 05:05 PM
