86 Z28 350 Carb, What Fuel Pump should I get?
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
I have a 650 Double Pumper on my 350, Mods below, I am running the stock 305 Fuel Pump ( Orginal with the car ) and would like to change it because I think it is time, Which one would you go with? Model # and Part # would be great thanks.
Car: 84 Camaro Z28
Engine: 355 Carb
Re: 86 Z28 350 Carb, What Fuel Pump should I get?
I wouldn't get the carter pumps
I went though a few of them myself since they either broke or gave up on me
I wouldn't know what to recommend sice I'm running a autozone one to get from a to b for now
Car: 86 Z28
I am leaning toward these two pumps,
http://www.summitracing.com/parts/hly-12-327-11
http://www.summitracing.com/parts/edl-1721
Which do you guys think.
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Nothing wrong with replacing it with an OEM style pump and you will still have the bypass system still hooked up. This allows the excess full to return to the tank instead of sitting in the fuel lines soaking heat up from the motor.
The Holley pump you have linked is what I have on my 86 T/A. Mostly for looks and it has worked really well since 2004 when I installed it but I have only put 12K miles on the car since then too.
A fuel pump is only going to help performance if the current pump is not delivering enough fuel to keep the bowls at the proper level and/or by not putting a load on the motor.
Car: 86 Z28
I just figured the pump on the Motor is from the original 305 and is at least 20 Years old since I never replaced it. It has sat a lot for the past 8 Years. Is it a problem not having the return hooked up?
Engine: Broke - 350
Using the Holley or Carter pumps without the return will work but you have to seal off the return line if you do this.
With it sitting for so long I bet the diaphragm has gotten hard. I'd replace it as well
Engine: LS1/LQ4
Transmission: 4L60E/4L80E
The Carter M6626 gave me zero problems running it for 5 years (up to the time the LS1 went in the car). It has the return. Good pump for a decent price, IMO.
Car: 86 Z28
I ordered the Edelbrock one earlier today,I hope it holds up.
theshackle
03-05-2017 06:37 PM
beachrodder
08-25-2015 08:05 AM
92camaroJoe
08-13-2015 06:07 AM
