Choke issues
Old Jun 3, 2013 | 05:52 PM
Spyder87IROCZ28's Avatar
Car: 1987 IROC Z28
Engine: 305 4BBL
Transmission: NWC T5
Choke issues
I have read several other threads about this problem the choke light is on on my 87 IROC I have 15 volts at he battery terminals with the engine running so the alt is good there is 14 something volts at the choke wire if I unplug the choke wire the light goes off I drove the car with no choke thermostat for about three weeks it starts hard of course but after its warm runs like charm I don't need the choke but this is technically my wife's car and she won't drive it with it like this very frustrating were do I go from here?
Old Jun 8, 2013 | 06:20 PM
Car: 1987 IROC Z28
Engine: 305 4BBL
Re: Choke issues
So I figured out that with the choke wire hooked up to the thermostat the volts would drop to aroun 4 so it thought the relay was bad but when I removed the relay there is still voltage at the wire ????? So I unplugged the factory choke wire and ran a wire with a fuse block to the fuse box and that's how it will stay for now maybe if I ever get around to swapping engines ill get a new harness from painless and fix it right
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MM2Robinson
Oct 1, 2017 09:16 AM
TheTraut88
Sep 11, 2015 05:16 AM
Fronzizzle
Sep 8, 2015 12:10 PM
