idle mixture adjustment needle
Old Aug 21, 2013 | 09:19 PM
JTV's Avatar
JTV
Car: 1987 Pontiac Firebird
Engine: stock LG4 305 ccc
Transmission: r700
Axle/Gears: 2.73 (turd)
Is this a air circuit or a fuel circuit and does it require a special tool. Im having a very slight hesitation right off idle. Am I starting at the right adjustment for this problem. 87 firebird LG4 CCC all stock except cat back flowmaster exhaust but I can see the plug on the circuit has been pulled out. Fresh tune on everything else. Kinda looks hard to get to. Thanks. Respect.
Old Aug 21, 2013 | 09:27 PM
Joe Tag's Avatar
Re: idle mixture adjustment needle
Idle mixture is just that. The ammount of fuel during idle. It does nothing once the throttle plates open. Sounds more like the accelerator pump is starting to fail to me.
Old Aug 22, 2013 | 01:23 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's an air and fuel circuit.
But, you probably aren't starting in the right place. What type of air cleaner do you have?
Old Aug 22, 2013 | 11:02 PM
JTV's Avatar
JTV
Transmission: r700
New fram filter in a stock air cleaner . I was thinking the idle circuit would effect off idle low rpm. Now Im wondering if its the pump going bad. It only happens when I barely touch the gas. If I push it more than 1/8 it there is no hesitation or stumble.
Old Aug 23, 2013 | 01:03 PM
five7kid's Avatar
If by "pump" you mean the accelerator pump, maybe.
Does the thermovac work in your stock air cleaner? Not having it will cause exactly the symptoms you're describing.
Old Aug 23, 2013 | 04:42 PM
JTV's Avatar
JTV
Transmission: r700
Yes I was talking about accelerator pump. I will check the thermovac. I didn't check it on recent tune up. I will post results. Thanks.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
IROCtometal
Sep 2, 2015 02:01 PM
