FUEL PUMP LINE LEAKING!!!
Car: 1988 camaro
Engine: 355 blueprint engine
Transmission: 700 corvette servo
Axle/Gears: stock 4.11
Okay so i had bad fueling issues at WOT pressure would drop so i replaced the pump with a new AC Delco pump pressures there now but now this line is leaking, what can i do to fix this?
http://i315.photobucket.com/albums/l...ellineleak.jpg
Car: !988 Camaro z28
Engine: Blueprint Engine Chevy 355ci
Transmission: 700 Corvette Servo
Axle/Gears: 4.11
Re: FUEL PUMP LINE LEAKING!!!
What would cause it to leak from there? Previous owner appeared to have replaced the pump sometime before with the "hatch door method" could the previous owner damaged the line where it goes through that part of the pump?
theshackle
Mar 5, 2017 06:37 PM
AkDrifted
Aug 17, 2015 07:45 PM
