Seafoam use?
Old Oct 4, 2013 | 10:01 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Transmission: TH-FO-HUNNIT
Seafoam use?
Hey guys. This might be a stupid question.. But how do I use seafoam? My oil pressure is really high so I'm going to use seafoam to see if I can't loosen the oil and I will do an oil change after I use it.. But how do I go about using it?
Old Oct 4, 2013 | 10:14 AM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: Seafoam use?
First off...how high is too high? My car starts at about 60 and as it warms up goes down to 35-40 while cruising, 30 at idle. I run 10-30 Rotella oil in it.
Old Oct 4, 2013 | 10:52 AM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Seafoam use?
It's constantly around 60, even at NOT.. Except when I floor it and let off the gas, it blips down to around 30 and then shoots back up.
Old Oct 4, 2013 | 12:30 PM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Seafoam use?
Factory gauge?
Old Oct 4, 2013 | 02:14 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
Re: Seafoam use?
yeah, sounds like your gauge is off, the factory gauges are known to be all over the place
but to answer your seafoam question, suck it in through a vacuum port, pour some in the gas tank and add some to your oil
sucking it through a vacuum port will stall the engine if you give it too much so go slow
Old Oct 4, 2013 | 02:30 PM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: Seafoam use?
Could be your sender unit too. My gauge would peg high and sometimes jump erratically.
Replaced the sender unit and it fixed it.
Old Oct 4, 2013 | 02:31 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Seafoam use?
Where is the sender located at? I could hopefully buy the part pretty cheap and maybe fix it?
Old Oct 4, 2013 | 02:48 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Seafoam use?
I have a carbureted 5.7 vortec engine by the way..
Old Oct 7, 2013 | 02:56 PM
midias's Avatar
Re: Seafoam use?
Probably by the distributor or the oil filter
Old Oct 7, 2013 | 05:59 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Seafoam use?
seafoam will do little if anything for your oil press. problem . your problem is the oil press. sensor . easy to change , located just above the oil filter . you said you had a 5.7 vortec engine . who did the swap ? has it ever read normal ? my guess would be sensor bad or not even hooked up or installed . good luck .
Old Oct 7, 2013 | 06:46 PM
Jonesyfxr's Avatar
Re: Seafoam use?
Mine is next to the distributor. It's tight back there!!!
Old Oct 8, 2013 | 06:10 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Re: Seafoam use?
Agreed. Also make sure you use the correct sending unit for the gauge you are using. If you car was originally a v6, use the v6 sending unit if you have the v6 gauges.
Old Oct 8, 2013 | 11:40 PM
JCS94's Avatar
Car: 89 Formula WS6
Engine: LQ4 h/c/i
Re: Seafoam use?
The swap was done before I bought the car. It had a v8 in it before, I do know that. I never checked when I first got the car, but about 20 miles of driving, a SES light came on and I am unsure as to what that is from.. But I will check this weekend if the sender is connected or not. I will let you know if you guys are ok with that.. If I have any more trouble. Haha
gta892000
Aug 11, 2019 11:16 AM
86White_T/A305
Mar 6, 2016 01:48 PM
HoosierinWA
Oct 7, 2015 10:15 AM
rjcme
Sep 5, 2015 01:23 PM
bakerstreet
May 29, 2007 09:56 PM
