CARBURETOR/INTAKE MANIFOLD COMBO SUGGESTIONS PLEASE HELP
Car: 1988 camaro rs
Engine: 2.8l
Transmission: automatic
hello I am rebuilding a 350 out of a parts car I bought and putting it in my car. I have everything on the swap figured out I have read countless amounts of threads. the wiring harness from the tpi setup is a mess and the ecm needs a prom burned and there are just too many electrical issues I would run into getting the 91 tpi system up and running in my 88 so I decided to throw a carb on it. if anyone could give me some suggestions on what carb/ intake to run I would GREATLY appreciate it. or if anyone has any advice to me that they think I would find helpful please feel free to let me know. Thanks so much.
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Re: CARBURETOR/INTAKE MANIFOLD COMBO SUGGESTIONS PLEASE HELP
To know witch intake and carb you are going to need depends on what cam exhaust ignition rpm range you looking for
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
We also need to know where you are. Do you live in a place that requires emissions testing?
86CamaroDan
Sep 29, 2015 10:08 PM
