idling problems
Old Apr 24, 2014 | 10:47 AM
shayapaula's Avatar
Car: 84 camaro z28 H.O
Engine: 305 H.O
Transmission: world class T5
Axle/Gears: 3.73 limited slip
idling problems
Im having problems with my 84 camaro, the stock quadrojet went out on me and i could find any one to rebuild it so i went with a 1406 edelbrock on a basicly stock 305. When the rpms get over 2500 it runs great but at idle it sounds like its going to die. Ive looked around on here and other forums and they talked about getting a difront distributor. Would that help or could i ajust the timing on mine? Thanks also this is my first post
Old Apr 24, 2014 | 11:22 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: idling problems
You need a distributor that has vacuum and mechanical advance built into it. Your stock distributor relies on the computer to advance the timing, but without the input from the original carburetor, the computer can't tell what the engine's doing so it can command the proper timing advance.
Hard to believe you can't find a rebuilt computer q-jet. Readily available on Summit ( http://www.summitracing.com/parts/ur...maro/year/1984 ), eBay, most parts stores. I'd gladly spend the $400 on a rebuilt q-jet before I downgraded to an Edelbrock and vac/mech distributor.
Old Apr 25, 2014 | 09:07 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: idling problems
Originally Posted by five7kid
.. I'd gladly spend the $400 on a rebuilt q-jet before I downgraded to an Edelbrock and vac/mech distributor.
And $400 is cheap compared to the money and aggravation you'll spend rounding up the parts and dialing in your converted "system". Not to mention the extra fuel you'll be burning compared to the stock CCC setup.
Old Apr 25, 2014 | 09:59 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: idling problems
Any mechanical, vacuum HEI should work just fine for your application
Spend what you want, here is a cheap one. Basically you will be out $50 to 350 depending on brand name, quality and markup.
Don't forget to also buy a timing light.
http://www.ebay.com/itm/New-Complete-DD-SBC-HEI-V8-Street-Fire-Chevrolet-Chevy-HEI-Ignition-Distributor-/251358748714?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a8626202a&vxp=mtr
Old Apr 25, 2014 | 10:05 AM
shayapaula's Avatar
Engine: 305 H.O
Re: idling problems
Allright, I'm most likely going to keep the edlebrock since it was given to me for my birthday, I'll order a new distributor and see how everything goes.
Old Apr 25, 2014 | 11:12 PM
five7kid's Avatar
What kind of transmission do you have?
Old Apr 26, 2014 | 09:41 PM
shayapaula's Avatar
Engine: 305 H.O
Re: idling problems
700r4
Old Apr 26, 2014 | 09:43 PM
shayapaula's Avatar
Engine: 305 H.O
Re: idling problems
i have the tv cables on the way for it
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
