intake swap
Old Aug 9, 2014 | 09:49 AM
Icantthinkofone's Avatar
Car: 1983 Z/28 wannabe
Axle/Gears: Detroit locker w/4.10's
intake swap
I recently installed an edelbrock 7501 performer air gap intake manifold in place of the weiand stealth. nothing else was changed. the car runs so poorly now it's almost not drivable. it's a 350 .40 over flat tops decked block .30 off the cast iron heads 292 .480 cam headers and 600 cfm edelbrock carb. i'm at a complete loss as to why it runs so bad. I've changed the jetting a couple times and haven't gained anything. any thoughts would be greatly appreciated.
Old Aug 9, 2014 | 12:15 PM
Re: intake swap
Apart from potential combo issues, main things I would be looking at, is installation malfunctions; gaskets that don't seal, hoses tha tleak, etc.
Old Aug 9, 2014 | 02:12 PM
Canucksfan1's Avatar
Car: 1987 z28 I-roc
Engine: Carbed 350
Transmission: 700r-4
Axle/Gears: Stock
Re: intake swap
What's the timing set at?
Old Aug 9, 2014 | 08:54 PM
Re: intake swap
base timing is @ 10degrees. as foolish as it may be I think the problem was a faulty base gasket between carb and intake. I have never experienced that.
midge54
Jan 29, 2017 07:00 PM
Keith5
Aug 27, 2015 04:37 PM
theshackle
Aug 22, 2015 06:52 PM
theurge
Aug 21, 2015 12:46 PM
