Carb rebuild....Where does this part go????
Car: 1992 RS Polo Green Coupe 86 IROC
Engine: 305 TBI
Transmission: Automatic
Axle/Gears: Yes it has some!!!
Hey guys. I'm rebuilding my quad carb and I'm ready to reassemble.....I can't find this part in any picture, parts fische, or third gen post. Where does it go????? I don't want to get it back together and find that it's in the deepest cravity of the carb. Thanks for your help. Matt
Re: Carb rebuild....Where does this part go????
Behind the choke bowl, in the hole where it gets vacuum from... it's a seal
Engine: 305 TBI
Thanks sofa king.....you saved me again. I hate that feeling when you see that part laying on the bench and wonder if it's a part you need or something random that the kids left on the table out of one of their airsoft guns or something stupid like that.
Your the man!!! On a side note... I started to reassemble the carb last night and noticed that my secondaires wouldn't open as needed. Looking closer the gasket was partway into the opening. Do you find it common to need to trim them to fit. This was a napa part specific for my carb. We used the stamped number on the carb to order it, so I know that it's for my carb, but wasn't too happy when I noticed that. I was going to mark it and trim it with an exacto knife and possibly a dremel tool. What do you think? Thanks Matt
Engine: 305 TBI
Ok, so maybe I need a picture with an arrow pointing to where it goes. I can't see where it would go. I guess I need some more guidence. I looked for a bit and I can't figure it out. Help. Matt
Your carb may or may not use it; can't tell whether it came out of it, or whether it was in the "kit".
If it belongs there, then when you remove the choke bowl, one of the holes on the bottom where it fits against the fuel bowl casting will have a bored-out place for it to go down into.
Part # 360 in this dwg.
Yes it is common for the gasket to need a bit of trimming. Not a big deal. I usually put em together and do it w a razor blade. (xacto knife)
Engine: 305 TBI
Well, if I'm looking at this fische correctly, it goes behind the choke assembly. I didn't pull the choke out, I did pull the electric choke coil out, but I didn't pull the housing or the linkages. Left well enough alone, I figured. Just trying to fix the pit wells and clear out all the passageways if possible. So it looks as if I'm safe. Let me know if that sounds right to you? Thanks again for the help. Matt
Engine: 305 TBI
Ok, this is the only place that I could figure out where it goes. Let me know if that is it or not.....
Engine: 305 TBI
I was reading on the site on a E4ME rebuild page. Is this the plastic aneroid cavity insert? It said that it is sometimes used and that it is located under the float bowl solenoid connector?????
Engine: 305 TBI
I found it. It's the plastic check valve in the fuel filter assembly.
Engine: 305 TBI
What releases the secondaries. I am operating the throttle body and the secondaries are locked up with that arm under the choke assembly. Nothing touches that arm. Am I missing something here or what?
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
a few pics here that may help:
https://www.thirdgen.org/forums/carb...-ccc-qjet.html
If you need more just post back and I can forward you pics of some carbs on my shelf.
If you go through naf's carb overhaul steps you will find your answer. In the picture where he is talking about the installation of the choke housing, he has already installed a lever on a nub on the main body. It has a notch in the end to catch the pin that you see going through the secondary throttle shaft. When the choke is on this will not let the secondary open. Hope this clears up your problem. Brian
86IROC112
Aug 17, 2015 02:00 PM
