sloppy spools
Old Aug 15, 2014 | 12:52 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
sloppy spools
10 bolt spools,..ive considered it as a cheap option until i swap out for a 9 inch. but how bad is the slop in between splines etc.?
Old Aug 17, 2014 | 02:46 PM
charlie894's Avatar
Car: 91 camaro, 90 mustang, f250 diesel
Re: sloppy spools
You may have better luck posting this in the transmission and drivtrain section. I've run spools in various cars over the years and never found anything that I would consider slop in the splines. Depends what your using the car for as to whether I'd run a spool though.
Old Aug 19, 2014 | 05:20 AM
Berlyn0963's Avatar
Car: 91 Camaro RS
Re: sloppy spools
fat fingers with my cell made this post in the wrong spot. thought the admins woulda moved it by now. idk how to move this thread so they can delete if they want.
Old Aug 20, 2014 | 08:40 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Re: sloppy spools
I don't understand your concern.
Unless you have defective or damaged splines, any "slop" with a spool will always be less than it would be with any differential.
cheesehomer
Dec 31, 2015 08:48 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
darwinprice
17
Oct 11, 2015 11:51 PM
greenyone
Sep 2, 2015 03:39 PM
fasteddi
Sep 2, 2015 10:29 AM
