secondaries
Old Feb 6, 2015 | 08:32 AM
formulating_88's Avatar
Car: 88 firebird formula
Engine: 383 c.I.d carbureted, 670 holley vs
Transmission: 700r4 (for now)
Axle/Gears: stock (for now)
secondaries
Hey randomly today my car started running badly. Wouldn't idle runs rough. Upon my search I found fuel on the intake that appeared to be leaking from the input shaft at the bottom of the diaphragm for the secondaries. I also noticed that the fuel is constantly dumping into the secondary bowls hence the flooding and rich conditions. I don't know a lot about carbs. My carb is a 670 holley vs only has about 2000 miles on carb.one of you carb masters please help thank you.
Old Feb 6, 2015 | 03:25 PM
bigal55's Avatar
Car: 88 convertible
Engine: 5.7L
Transmission: 4+3 maual
Axle/Gears: 3.07
Re: secondaries
Check your float level. If gas is constantly running into the secondaries, your gas level in the bowl is too high. Could be a bad needle and seat not sealing, float sinking not raising the needle to seal off gas or simple float adjustment. That's where I would start.
GL and let us know.
Old Feb 6, 2015 | 04:15 PM
Re: secondaries
Definitely going to replace seat and needle. Adjustment to float level made no difference so I would assume seat and needle would be the proper fix thank you for your feedback and happy motoring.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
sreZ28
Oct 22, 2015 08:21 AM
racereese
Oct 10, 2015 09:39 PM
RedLeader289
Sep 23, 2015 06:50 AM
gta892000
Sep 16, 2015 12:37 AM
