Need to find Carb to air cleaner adaptor?
Old Mar 8, 2015 | 12:37 PM
1986power's Avatar
Car: 1986 Chevy Camaro Z28
Transmission: stock
Hey im running an edelbrock 600 cfm performer series 4 barrel carb on a 1986 camaro 5 litre. Recently, the plastic collar that sits on the carbeuretor and the air cleaner housing sits on was stolen. is there some place I can buy just that collar, or does it come with air cleaner housings/carbs only when you buy them? I've checked Napa, Canadian Tire and Parts source auto value and havent found any luck.
Old Mar 9, 2015 | 10:31 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: Need to find Carb to air cleaner adaptor?
You know, I've only seen them on carbs when I buy them...check a junk yard maybe or a carb shop? Cliff ruggles at cliffshighperformance.com might sell them.
Old Mar 9, 2015 | 10:14 PM
steve87ta's Avatar
Car: 1969 firebird, 1986 Trans Am,
Engine: 461,305TB
Transmission: T-10,700r4
Axle/Gears: 3.55,2.73
I think summit has them in different heights.
Old Mar 10, 2015 | 06:10 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
This? http://www.carid.com/mr-gasket/air-c...Ef0aAg-V8P8HAQ
Advance used to keep this kit on the shelf. Same isle as the rest of the Mr. Gasket/Proform stuff.
Old Mar 10, 2015 | 07:13 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
http://www.summitracing.com/search/p...sembly-spacers
Here are a bunch on ebay search air cleaner riser
http://www.ebay.com/sch/i.html?_odkw...Text=&_sacat=0
Vintageracer
Jan 10, 2020 05:33 PM
86IROC112
Sep 7, 2015 01:37 PM
86IROC112
Aug 17, 2015 02:00 PM
wruiz
Aug 13, 2015 09:07 PM
92purpz28
Aug 11, 2015 02:30 PM
