True c.a.I.
Old Dec 8, 2015 | 01:15 PM
dixie wrecked's Avatar
Car: 91 ws6
Engine: Carb'd 334 stroker
True c.a.I.
Hello all, I have a bird with a 334 and holley 600, was looking at making a true c.a.I. system.
Not an off the shelf one.
What I was looking at doing is basically using an existing aftermarket air cleaner, making it enclosed with tubing, and running the tubing to the front hood vents. Cut out the metal under the vents and attach it there, so that way I would be sucking in air from in top of the hood.
Would a setup like this work? Never mind ugly, this thing could be a double in any Mad Max film lol.
Old Dec 9, 2015 | 07:55 PM
Damon's Avatar
Re: True c.a.I.
Anything is do-able. If you want it to draw from the top of the hood (not an ideal location without a forward-facing scoop) you might find it's easier to build a seal up between the outside edge of the air cleaner housing and the underside of the hood and then cut holes in the air cleaner lid so it will suck the air in from above the air cleaner- no need for hoses.
Old Dec 9, 2015 | 09:31 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: True c.a.I.
I'd take cold air from the base of the windshield cowl like Smokey Yunick did.
Old Dec 11, 2015 | 11:33 AM
pancherj's Avatar
Car: 1990 IROC
Engine: Rebuilt L98 with H/C/I/Carb
Transmission: TH350 with ATI Treemaster
Axle/Gears: 7.5 with 4.10's
Re: True c.a.I.
I used my IROC TPI intake (with cold air tubes running down to the fog light area) and mated that to a sealed air cleaner with a tube as you mention. Works on the Camaro, but probably not on a Trans Am.
Old Dec 11, 2015 | 11:50 AM
Car: 91 ws6
I don't have much room there, sadly. I run a 2" carb spacer, with the most backwoods lookin carb cowl/cover bolted to my hood lol.
I realize anything can be done, I just didn't know how effective it would be sucking air from the front vents atop the hood.
Sounding like my best bet is to just make a cowl and make a home made shaker type setup. The uglier the better lol! She's a junkyard dog
gtopat
Nov 9, 2016 01:22 PM
esc
Brakes
27
Dec 15, 2015 02:12 AM
husker2733
Dec 3, 2015 02:56 AM
Badmechanic125
Nov 29, 2015 06:22 PM
Jonny45
Nov 24, 2015 12:48 PM
