Carb inlet pressure gauge
Car: 82 Z28 Camaro
Transmission: BW super t10
I recently installed a fuel inlet line kit on my edelbrock 1406 and a pressure gauge between the filter and the carb. My gauge bounces from 0 to 4 back to 0 constantly and i was wondering if that was normal since i have a mechanical fuel pump as it driven by the cam? I have looked for leaks and have none.
Car: 82 Z28 Camaro
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Re: Carb inlet pressure gauge
when the carb needle/seat opens you can expect the pressure to drop as the bowl fills.
Car: 82 Z28 Camaro
[QUOTE=Boz2882;6031301. My gauge bounces from 0 to 4 back to 0 constantly and i was wondering if that was normal since i have a mechanical fuel pump as it driven by the cam?.[/QUOTE]
Do you have the stock pump? How many miles does the engine have?
The reasons I ask are: 4 psi is somewhat low and some engine oils won't properly lubricate the fuel pump camshaft lobe. I had one wiped out completely. Nasty business. It stated to show itself much the same way yours is now.
Car: 82 Z28 Camaro
Eric-86sc
Apr 3, 2016 09:56 PM
