Q-jet secondarys are stuck
Old Dec 26, 2001 | 09:27 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
my secondarys are really tight on my Q-jet. when you push on them they are hard to get open. i think what happened was that i used lock tight on the air cleaner stud. i think the lock tight dripped down and caused it the freeze up a little bit. any suggestions on cleaning it or any meathod on getting to work freely again would be great. thanks alot.
Old Dec 26, 2001 | 09:49 PM
buickman's Avatar
do the secondaries loosen up as th engine warms up? if so that's normal, to keep you from getting wot when th eng. is cold. if not, might try popping the top off the carb and soaking it in carb cleaner, which would be a great time to "overhaul" the carb, and see if it will remove the loc-tite.
tmellott89
Oct 14, 2015 02:06 PM
racereese
Oct 10, 2015 09:39 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
corey8084
Sep 17, 2015 02:56 PM
gta892000
Sep 16, 2015 12:37 AM
