84 Camaro H.O cold starting problem.
Old Aug 30, 2017 | 05:49 PM
That80sdude's Avatar
Car: 87 Camaro Z28/ 84 Camaro Z28 H.0
Engine: 305 tpi / 305 H.O
I have a 84 Camaro Z28 H.O with a carburetor and manual fuel pump, the problem I'm having is when starting cold in the morning I have to pump the heck out of the gas to get it to start. Im talking 3-4 attempts at starting the car and pumping the gas over and over. After the car finally starts , it will then start up all day long, every time as soon as I hit the key.
Do you think this is a carburetor or a fuel pump issue?
Old Aug 30, 2017 | 06:05 PM
dlinger's Avatar
Car: 1984 Z28 HO
Re: 84 Camaro H.O cold starting problem.
If choke is working and you are setting it correctly before starting, the fuel may be leaking out of the bowls. You may need disassemble and epoxy.
You can see where mine was done on previous rebuild.
Old Aug 30, 2017 | 08:44 PM
I'm definitely leaning towards yanking the carb and rebuilding it. It runs great once it finally starts. I should just have to hit gas once to set the choke right?
Old Aug 30, 2017 | 08:46 PM
There is this clicking noise under the hood when I turn key on. Ive not found where that is coming from. It only clicks when you turn key on not when its running.
Old Aug 30, 2017 | 09:07 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
clicking sound is a mixture control solenoid tapping away. its basically a needle jumping up and down metering fuel flow.
Old Aug 30, 2017 | 09:57 PM
gt4373's Avatar
Transmission: 5-Speed Manual
Yes,If You Listen Closely You Can Hear It Set.
Old Aug 31, 2017 | 09:16 AM
dlinger's Avatar
Car: 1984 Z28 HO
I would take the air cleaner off and operate the throttle linkage by hand, all the way back and release. The choke plate should close. If it does, I would hold the choke plate open with one hand and repeat while watching inside the primary to see if you see fuel squirting (I think you can see it in Rochester's, someone chime in if you can't - I know Holley is evident). If you don't see the fuel squirt, the bowls are probably dry, and the fuel leaked out.
Old Aug 31, 2017 | 07:12 PM
NoEmissions84TA's Avatar
Or the accelerator pump cup has shrunk and is not pumping.
