Quadrajet l69 305.
Old Sep 15, 2018 | 12:38 PM
Hunterclementz's Avatar
Car: 84 z28
Engine: 305 l69
Axle/Gears: 3.08?
Quadrajet l69 305.
Hey everyone i have a 84 z28 it has a quadrajet carb and it runs too rich i was told i have to punch out the two plugs in the front of the carb to adjust the air/fuel it also has headers with no o2 sensor i was wondering if i could reflash the cpu and adjust the air/fuel from the computer if anyone has ever had any luck with this please let me know thanks
Old Sep 15, 2018 | 06:55 PM
NoEmissions84TA's Avatar
Re: Quadrajet l69 305.
Are you still using the CCC QJet carb?
If so, what you have been told WILL NOT WORK.
Without the O2 sensor, the ECM has no idea how to control the carb - and the distributor advance.
You either have to get the complete CCC system running again,
or abandon computer control completely and use a manual carb and distributor.
You also have to find a way to control the TCC torque converter lockup.
https://www.thirdgen.org/carbswap/
Old Sep 15, 2018 | 07:32 PM
Bow_Tied's Avatar
Car: 1987 IROC-Z
Engine: L98 5.7L
Transmission: MD8 700R4
Axle/Gears: G80 GW6 3.27:1
Sounds like it would be easier to get a bung welded into the header pipe or header and put in a new O2 sensor. good luck with repair.
Welcome to TGO.
Old Sep 16, 2018 | 07:45 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
throw a photo on here of the carb with the air cleaner off.
hartsmike
Nov 11, 2019 07:20 AM
Gsoleski
Jun 13, 2015 09:19 PM
'84TA w/L69
Oct 17, 2003 01:46 PM
salty
Jan 7, 2002 07:52 AM
Alan84TA
May 10, 2001 08:05 PM
