Holley Tune and Fast Idle Cam
Old Sep 11, 2018 | 03:10 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If the primary transition slot has been reduced and the secondary screw is being used to set the idle, will there be an interaction/issue with the choke's fast-idle cam?
JamesC
Old Sep 12, 2018 | 08:30 AM
Re: Holley Tune and Fast Idle Cam
Generally, yes: the fast idle needs to bump the throttles up by some appropriate amount from wherever they are at normal curb idle, therefore if their location at curb idle changes, the fast idle setting will change too.
Best way I've ever found to adjust it is to set the idle speed part of the choke linkage when the car is hot and turned off, start it up without touching the gas, and adjust to about 15 - 1600 RPM to start with; then just dial it in from there on cold mornings. The pulloff setting may need help too; if it seems too rich or lean at cold startup, i.e. if it either runs real rough and sputters and the idle seems to slow down after the first few seconds vs if it seems to run somewhat OK but if you give it a small amount of throttle it wants to die, then increase or decrease the amount of opening respectively.
Old Sep 18, 2018 | 07:23 AM
JamesC's Avatar
Over several mornings, I verified the fast-idle speed and then adjusted downward until I achieved the 1500/1600 range. The choke setting itself seems perfect. So all's good.
JamesC
StringRust
Carburetors
Aug 12, 2011 10:37 AM
LowStyleII
May 11, 2004 11:43 PM
Jurrel
Carburetors
Feb 1, 2003 02:13 PM
TBI305Camaro
Carburetors
Nov 14, 2002 10:26 AM
