Tune up and still dies need help fast
Old May 4, 2004 | 09:04 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Ok i went to get my car tuned up cuz of the idle surge plus it needed it anyway. Well the total was about 200 bucks for that and some other crap that needed replaced like plug wires and such. Well the guy told me that to stop the idle surge i would have to replace my IAC he was gonna charge me 150 bucks to do it. So I did it myself. The instructions said to get it to like 13 inch pounds. Isnt that like finger tight? Well lets just say its tight. Would it still do this if the specs werent met? What else could i check for? It might be a vaccuum leak as well. So I might just replace all my hoses leading up to the TBI. Lemme know what ya'll think. Thanks and yes i did search some stuff and tried to fix it.
Old May 4, 2004 | 09:28 PM
steve8586iroc's Avatar
Have you tried spraying carb cleaner around the vacuum lines and the base of the tb to find out if you have any leaks? Also you might try taking the casper thing off and just hook the tps back up stock.
Steve
Old May 4, 2004 | 09:37 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
Those mods are on my wish list and yes I have cleaned it out with carb cleaner. It looks like theres some gunk in the bottom of the TBI when i open up the butterfly valves.
Old May 4, 2004 | 09:41 PM
I guess I didn't explain it very well. Take the carb cleaner and with the engine running spray it aroun the base of the tb and around all your vacuum lines. If the engine speeds up or smooths out you know you have a vacuum leek in that aera.
Steve
Sorry I didn't catch that the stuff on the bottom of the post was your wish list. I dodn't think the tps enhancer will do to much or what you expect it to do.
Old May 4, 2004 | 09:42 PM
LowStyleII's Avatar
Car: 1998 Camaro
Engine: V-6 200 HP
the engine wont stay running so hows it gonna smooth out. I have to keep giving it fuel when i spray that stuff or it will die even if it was still running. But i could check the hoses.
Old May 4, 2004 | 09:45 PM
Have a friend keep ti running at as slow of a rpm as possible. Don't spray the carb cleaner in the tb but at the outside of the base where the tb gasket is.
Steve
Old May 9, 2004 | 12:46 AM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
i think youd gain more by having a custom chip made rather then spending $ on a TPS enhancer.
Old May 9, 2004 | 02:24 AM
hellraiser319's Avatar
does it smoke at all when it does run? are the fuel injector connectors on tightly? if one isnt on good enough or a fuse blew or whatever else and one injector doesnt fire well enough or at all then the engine will run very bad or not at all. my prongs that hold mine on broke off and the one slips off sometimes and it runs like a drunken 4 cyl. id check the fuel injectors out for electrical connections and make sure theyre firing rite. also if its smoking and was otherwise running well before, check the tps to see if its loose cuz if it is it could be running horribly rich or lean depending on how it slipped. i regasketed mine recently and my tps was off a slight bit and smoked everywhere but moved it around until it ran nicely and smoke free. dont really know what else to say.....
hellraiser and the red thing
Old May 11, 2004 | 11:43 PM
ShiftyCapone's Avatar
Supporter/Moderator
Car: '90 RS
Engine: 377 LSX
Transmission: Magnum T56
What is your base timing set at? You can have a bad surge if you are running to far retarded.
Bubbajones_ya
Jul 6, 2024 08:32 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
customblackbird
Oct 1, 2015 04:30 PM
R13_Braz
Sep 18, 2015 05:00 PM
