Mpfi to carb
Car: 1987 Firebird
Engine: 2.8L V6
Mpfi to carb
I’m switching my 2.8 V6 over to a 350 and I’m wondering if I have to do is disconnect the throttle cable from the throttlebody and put it out of the carb for it to work… And does that mean that I could essentially remove the entire computer?
Car: 1989 Pontiac Firebird
Engine: 383
Transmission: WCT5
Axle/Gears: 3.23Posi
Re: Mpfi to carb
I'm sure someone with more experience will chip in, but I am in the middle of swapping a 305-T5 car to carb, and I'll pass along my notes. I assume your car has either a t5 or a 700r4., the 700r4 should just need attachment for the TV cable, and most aftermarket and GM carbs have one. If you by some odd chance have a 4L60E, you need a throttle position sensor, which is available for most aftermarket carbs. If you have a T5, you are good.
The computer on these cars runs the fuel injection but I am not sure if it is connected to the gauges and radio. . .
Re: Mpfi to carb
The V6 and the V8 use the same ECM. With some wiring changes and a V8 MEMCAL it could run a V8 TPI setup.
GD
GD
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Mpfi to carb
I don’t think the 1227302 can drive 8 injectors. It might be better to repin and get a 1227165 and maf. Or get a harness and double check C100 compatibility.
WyoCamaro
Alternative Port EFI Intakes
Feb 9, 2006 01:52 AM
