Which intakes clear firebird stock hood?
Car: 85 Camaro
Engine: Cadillac 500
Transmission: TH400
Axle/Gears: 9 bolt
Anybody have a definite carb height or intake p/n that will clear the stock trans am or Firebird hoods with a Holley 600vs and drop base air cleaner? Currently I have stock aluminum intake , carb adapter and 3/4" spacer with l69 air cleaner and it BARELY rubs the bottom of the hood supports. Looking to change over to vortec heads with an aftermarket intake and 14x3 drop base air cleaner.
Car: 88 Firebird, 87 Formula
Engine: 2.8, 5.0
Transmission: both 700R4
Axle/Gears: 3.42,3.45
Re: Which intakes clear firebird stock hood?
I have an Edelbrock Performer. NOT the 360 model. I had an Edelbrock carb, a 1" square-to-spread bore spacer, and the stock air cleaner housing (also a 10" filter) It barely fit. I'm back to a Q-jet (non-emissions) and stock gasket with the stock air cleaner- it's fine- a whole 1/4" .
Car: 85 Camaro
Transmission: TH400
Axle/Gears: 9 bolt
Is your intake like this one?
https://www.edelbrock.com/performer-...fold-2101.html
The one I just got is this one
https://www.jegs.com/i/JEGS/555/513002/10002/-1
Based on the published numbers I think it is about 5/8" taller. Hopefully it will still fit!!
Car: Dad's 87 Bird (Org Owner)
Engine: Vortec 350 Crate Motor
Transmission: TH350
Axle/Gears: 3.42 Posi
I have Vortec heads also. I use a Chinese knock off Ebay Air Gap with an Edelbrock 600 carb and a drop base 14x2 air cleaner. Has about a 1/4 inch clearance with a stock 1987 Firebird hood.
Engine: 2.8, 5.0
My car is an 87, so I used this intake... Same as the 86-down intake, just the holes are angled differently.
https://www.jegs.com/i/Edelbrock/350/2104/10002/-1
z28z34man
Jun 16, 2006 12:21 PM
