For those who pulled their tpi off to go carb. Any regrets ?
Old Feb 7, 2019 | 04:45 AM
moneyman380's Avatar
Car: 1991 Z28
I'm currently running a 355 tpi superramed 91 z28 but I'm really getting tired of all this tuning **** on my 730 ecm and about ready to yank off the superram and switch to a Holley carb. Money is not an issue since the superram is worth a chunk of change and the matching twin 58mm throttle body with two NOS plate setups. But what I want to know is from the guys who pulled their fuel injection to go carburetor have you regretted it and should I do it as well ?
Old Feb 7, 2019 | 07:42 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: For those who pulled their tpi off to go carb. Any regrets ?
It all depends on the purpose of the car. I switched to carb, removed the a/c & heater. I also ditched the 700r4 trans for a 3500 converter / th350 trans.
I did the skinny drag wheels in front and removed the front swaybar .
Now i want to put it all back to enjoy the car more. but thats my story. Did I enjoy my racing time, yeah.
If you do decide to go carb, I can hook you up with a nice Holley 750 Street HP carb.
Old Feb 7, 2019 | 08:34 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If you do go that route, save all your EFI stuff. You'll be back...
Old Feb 7, 2019 | 09:15 AM
Abubaca's Avatar
Don't let the car beat ya!!! What tuning issues are you having?
Old Feb 7, 2019 | 09:25 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Stick with EFI if you are hating the TPI then go some aftermarket EFI. Forget carb
Old Feb 7, 2019 | 09:35 AM
BizJetTech's Avatar
I'm following this as well.....to those who have gone with an aftermarket EFI.....what kind and how do you like it?
I was thinking of a new Edlebrock Pro-Flo 4......thoughts??
Old Feb 7, 2019 | 09:54 AM
Abubaca's Avatar
Holley HP. Love it.
Old Feb 7, 2019 | 10:04 AM
BizJetTech's Avatar
Originally Posted by Abubaca
Holley HP. Love it.
Sent you a PM
Old Feb 7, 2019 | 10:55 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Noooooooo
Old Feb 7, 2019 | 02:59 PM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
I made that swap and was happy about it until I went to sell the car. Everyone turned their nose up at the idea of a carb swapped engine and I lost a ton of $. If I had left it stock I imagine I could have almost doubled my $ the car was so clean. It depends I guess if you are going to keep it and are happy with the carb and MORE power. But..if you sell it ..it will come back to bite you.
Old Feb 7, 2019 | 04:34 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
I switched from a 305 TPI to a carb'd 383 and am already researching aftermarket efi systems.
the holley sniper efi is smack dab in the middle of keeping fuel injection and going to a carb. super easy self tuning apparently
Old Feb 7, 2019 | 04:38 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
This must be one of those infinite scroll 1984 threads, no?
Old Feb 7, 2019 | 05:58 PM
zed-028's Avatar
Car: 1987 Z28 Camaro
Engine: 305 LG4 4bbl
Transmission: TH700R4
Never looked back... or forward... whichever way you look at it. Elegance in simplicity.
Old Feb 7, 2019 | 08:32 PM
Car: 1991 Z28
Just having trouble dialing in the bin file. I'm no expert at tuning
Old Feb 7, 2019 | 08:52 PM
daferris's Avatar
Car: One owner '88 IROC 50k
Engine: L98 with bolt ons.
Axle/Gears: 3:42 again
consider Rbob's dynamic EFI It uses the stock '730 ECU but adds a flash based board to replace the prom.
VERY easy to tune and it self learns
I love mine...
https://www.dynamicefi.com/EBL_P4_Flash.php
Old Feb 7, 2019 | 11:05 PM
Car: 1991 Z28
I'm using an ostrich 2.0 as my emulator so I can tune on the fly
Old Feb 8, 2019 | 02:20 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
This!
I am one of those people... I assume one of two things when I see a car like this.
1. At some point in it's history, it had a problem that could not be resolved and the person thought it was easier to go to something they knew instead of taking on the challenge of actually correcting the issue. This is probably how the rest of the car was treated and other short cuts were made instead of items being done correctly.
2. Owner or a previous owner didn't understand fuel injection and wanted to hop it up and ripped everything apart and installed what they knew instead of doing research and building it the right way. Other items in the car have also probably been treated the same and shortcuts were taken.
I never assume it was a well thought out plan. It is a used car that has probably had multiple owners and who knows what the actual reasoning was. You have to plan for the worst, even if you hope for the best.
My brother dropped a 350 w/LT4 Hotcam in his TBI equipped RS. Couldn't seem to get the tune right so he went to a carb. It was a bit more of a different situation as we know the TBIs are not as desirable as TPIs, it had a rear end swap from a 2.73 Open to a 3.73 posi, ungraded brakes, 4th gen seats, built 700R4, new paint, cowl hood... and I could keep going on. The whole car had been changed. When he went to sell his car, the market for a hot rod RS is different than those for an IROC/GTA. Plus, it was all sorted and didn't have a lot of connectors and wiring hanging around, including the proper blower housing for removing the A/C. I believe it fit into a different market than opening the hood of an otherwise stock appearing car and discovering someone swapped in some random carb/intake/vacuum distributor.
With that being said, this is 2019, not 1990. There is really no excuse to not find the information to get a fuel injection system to run properly these days. Plus multiple options to go with if you no longer want to stick with the factory system. We all know they are a much more efficient than carbs overall. Though, I think you have to consider the overall car when deciding if jerking the fuel injection off is the right thing to do. Some won't care, some will. Those who don't care are probably not the people that are going to pay top dollar for a nice car either.
Old Feb 8, 2019 | 02:27 PM
BizJetTech's Avatar
The only other thing I'd consider (other then OEM TPI) would be installing a Holley HP EFI or Edelbrock Pro-Flow IV EFI system.
I'm all about "old school" but would never remove an OEM TPI (or even a TBI) system and install a carburetor in it's place....
IMO, those are for the 1st and 2nd gen cars, NOT our 3rd gen cars.....but that's just me, everyone has different thoughts on this stuff and it's fun
to see what others do as well.
Old Feb 8, 2019 | 02:29 PM
KyleF's Avatar
Car: 1988 IROC-Z
Engine: 5.7 TPI
Axle/Gears: 3.45
MORE power.
Carb's are not power adders... they do not make more power. All things equal, they make less due to poorer fuel mixture distribution, produce more emissions by not being infinitely adjustable while driving, and get less fuel economy.
As I said above, there is a difference in building power the right way. With a TPI it requires a short runner designed manifold to replace the long runners. This is usually more expensive than a carb. The only reason why you can say a carb makes more power than a TPI is because of the intake manifold change when you put the carb on. It will no doubt breathe at higher RPMs better than the factory runners/manifold does.
Old Feb 8, 2019 | 02:39 PM
midias's Avatar
I have to agree when I see a TPI swapped to carb for the sake of "old school" or more power you cna instantly infer it was most likely a hack job that makes less power, less MPG and was a result of someone not knowing how to work on a TPI car.
Cant wait to EFI my TA
Old Feb 8, 2019 | 04:43 PM
GeneralDisorder's Avatar
Before I say this - I would never remove the FI on anything - I'm an experienced tuner, I own a 2000 HP DynoJet, and I have EBL TPI on my personal daily.
But yes in some circumstances carbs can make more peak power than a TPI system - this stems from them being a wet manifold and the cooling benefits that come with it. A wet manifold at high flow rates is considerably cooler leading to a cooler, denser charge - this will make more power. This is of course not the case with TBI. But in the specific case of the dry manifold TPI system it is the case that a carb will make *slightly* more peak power. Engine Masters showed exactly this in a couple different episodes. If you could cool the TPI manifold or insulate it from engine heat the difference would be mitigated but I doubt there is any way to eliminate it entirely.
EFI wins in every other way, and again the carb advantage over TPI certainly is very small and not worth worrying about. I would NEVER pull off a TPI system to install a carb.
GD
Old Feb 8, 2019 | 06:40 PM
Car: 1991 Z28
Well I guess you guys talked me out of it. Superram stays on. Just going to have to keep fighting the programming
Old Feb 9, 2019 | 07:26 AM
dmccain's Avatar
Car: 89 Firebird
Engine: 355 TBI
GD
Very well stated and my thoughts exactly. I am swapping engines soon and initially was going from TBI to carb. I have changed my mind and will do the best I can do with the TBI its a very reliable and simple system I have grown to like. Not trying to make it a hot rod anyways I just prefer 350s and I want more than 170HP. I love TPI and its iconic on these cars. In saying that I can tell you two different occasions we took TPI systems off 350 cars and went to carb setups and the cars would run solid high 13sec 1/4 trips in comparison to low-mid 14s with the TPI setup. That's all I was saying.
Old Feb 9, 2019 | 01:14 PM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
I love my Qjet. It's easy to work on, to diagnose, to tune etc. I've learned so much from tinkering with it. And I love the power I'm getting out of mine.
Mind you, my car was originally Qjet equipped, and I'm the guy that would buy a new L69 car over a TPI car if given the choice back in the 80s.
That being said, I wouldn't convert a TPI car to a carb. I would work out the bugs and get it running right.
Old Feb 9, 2019 | 01:39 PM
ULTM8Z's Avatar
What sort of running issues are you having?
What cam and heads are you running? Maybe we can help if you want to post up in the DIY PROM section?
Old Feb 9, 2019 | 02:44 PM
Car: 1991 Z28
Engine wants to die when just idling and it's running extremely rich. Have a fully built up 355 forged internals, superram, 58mm throttle body, nos wet plate, 36lb injectors , dart pro heads ported and polished, 1.6 roller rockers, comp cam xfi cam dont remember specs. I'll have to look it up
Old Feb 9, 2019 | 04:57 PM
ULTM8Z's Avatar
so a couple of things...
do you have a WB O2 hooked up? that cam is pretty wild at 242 duration @.050 (if I'm looking at the right one). you'll definitely need a WB to get it running properly.
the other thing is I would start with the SAUJP bin as your start point and then change to open loop idle. you'll be able to precisely dial in your idle AFR to where the engine is happy. I got sick of fighting closed loop at idle with my Miniram. it likes to idle at about 13.5:1, and I could never get there with closed loop, nor get a decent throttle tip in.
I'd also go the extra step of getting TP RT to read the WB. that'll help tremendously in tuning the off idle and WOT AFR.
Old Feb 9, 2019 | 05:26 PM
Car: 1991 Z28
Yeah I bought a WB o2 setup with gauge. Have yet to setup the wideband output into tunerpro though. Was just told how to do it on another thread. It's a Innovate Motorsports 3918 MTX Series MTX-L Plus Wideband Gauge. What was recommended as a good setup to get.
Old Jul 7, 2019 | 02:42 PM
Marc Webber's Avatar
Car: !982 Trans Am
Transmission: 350 Turbo
Axle/Gears: 3.08
I love my carb. Slayer quick fuel 750cfm on my generation 1 350 with vortec heads. It depends on what you do with the car though. I drive mine regularly on the street and pretty much problem free. Keep in mind I have a friend that I've known since nursery school who now builds race engines and if I get in trouble he bails me out.
Mortorq
Carburetors
Feb 7, 2019 09:54 PM
camaro1185
Jan 16, 2012 12:49 PM
red85berlinetta
Carburetors
19
Nov 21, 2004 09:52 PM
Kory-88Iroc 350 tpi
Aug 19, 2004 07:39 PM
StylnCamaro
Nov 10, 2003 01:06 PM
