tpi-carb any regrets
Old Oct 5, 2003 | 12:38 PM
StylnCamaro's Avatar
I was just wondering for the people that went to carb from TPI have you any regrets at all or happy that you switched. Plus can you use the 23 degree heads we hav on the 350 TPI to convert to carb or new heads needed? But please let me know your regrets
Old Oct 5, 2003 | 12:41 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
mmm, have two friends that did it, lots of regrets...about not doing it sooner. the heads will work fine, most of them don't flow great numbers, but they work.
Old Nov 4, 2003 | 12:21 AM
N8Miller's Avatar
my opinion is that TPI would make for better driveablity. if you go carb, yes, it will be cheaper, but im not thinking it will be as smooth on the streets. the TPI cars make a ton of torque, so get a nice setup ported and some decent heads.
Trickflow uses the 23* heads, some people dont like them, but trickflow does produce some great #s. i would get a set of edelrock heads ported at L&B (seen their work recently-----look great)and get a intake ported too. heck, then hit it with a 100 shot if you dont go cheap with hyperutic pistons, stayed forged.
PS, never caught you downtown, too bad! i like to win
Old Nov 4, 2003 | 01:09 AM
x_wolf's Avatar
Car: 91 Camaro RS
Transmission: 700R-4
if its set up right you won't lose any driveability. if you wanna do it go for it. though that fuel injection can go a long way too with some work
cheers
Old Nov 4, 2003 | 04:57 PM
X86TRANSAMWS6X's Avatar
Car: 87 Conquest TSI, 86 Fiero GT
hey, if u wanna trade that tpi setup for my carb setup ill b gald to
Old Nov 10, 2003 | 07:55 AM
Kontrax's Avatar
Car: 86 Camaro
Engine: L98 350 bore .060 out, Carb power
Transmission: slusher 700 beatbox
im glad i went with a carb. more power, easier to work on. just lose the get in and go like tpi. carbs need tuning and maintence unlike FI...more torque with tpi? i think carbs make more power, HP and torque...
Old Nov 10, 2003 | 08:19 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just FYI... 23* heads are "stock"... they have been the norm on SBCs since the 50s when the engine first came out.... the greater majority of intakes (both FI and carb) are for 23* heads.
Old Nov 10, 2003 | 09:32 AM
Blackroc86's Avatar
Car: 1986 Iroc
Engine: 454 Demon 850DP
Transmission: TH350, 3500 stall
I switched from TPI to carb and I am very happy with the results. However my car is mostly a strip car and I am not worried about driveability per se. I went from 041 heads and the TPI setup to Fastburns, 1.6 roller rockers, Victor Super Vortec intake, Demon 850DP and dropped 2 full seconds off my 1/4 mile et's. If you have a daily driver I would stick with EFI.
Old Nov 10, 2003 | 01:06 PM
nolanr0413's Avatar
Car: Trans am
i wanna swith from to tpi to carb when i put a 385 in the car , I wanna loose all the extra wires and clutter , and put a cut out where the cat goes. I dont drive the car every day but i do go to car shows and want less clutter. If the carb is set up fine then you should have no problems with street drivability .
BurlyChev
Aug 22, 2015 11:42 AM
v8nate92RS
Jul 6, 2004 01:38 AM
Captain C
Jun 25, 2004 06:12 PM
Remondi2
Feb 15, 2001 01:10 AM
Coop91RS
Aug 1, 2000 08:43 PM
